IL 96 EK Coupe, FULLY BUILT D16Z6, TRADE ! testing waters!!!
Testing waters. Want to trade my fully built D series, mainly looking for a swapped 4 door ek. Whole motor cost atleast $3000 in parts and labor.
Head and Bottom end was built by Bill at Apex. I can show you the papers as well. Their is only 3800 miles, i have not beat on it due to me breaking the motor in.
The reason i want to trade it is because i do not have money to finish my project.
Dont need people talking **** about in my thread, thanks.
I will be taking my Si rims with the car as well.
Very healthy motor, Using Mobil synthetic.
Head- BRAND NEW OEM HONDA GASKETS
Ported and polished
Supertech Valve Springs and Retainers
Gasket matched
5 angle valve job
Bisimoto Stage 3 Camshaft N/a
Bisimoto Cam gear
Skunk 2 Pro Series intake manifold
B16 Throttle body
Brand new ARP headstuds
Bottom End-
Ycp Vitara Pistons, 8:5:1 Low compression
Eagle H Beam Rods
Golden eagle block guard
Ported z6 Pump, idle is 25 psi, (good oil pressure
Tapped oil pan
Innovative 75a Motor mounts, very stiff
Acl rod and main bearings
ac and ps deleted
Trans-
S40 ex trans
3800 Miles on Xtd stage 3 clutch
7lbs flywheel
5 Speed Manual
Short shifter
Bad-
Left quarter panel has rust
Trunk has 4 holes
black housing headlights were painted and now its peeling
Needs new front brakes
When the motor was being put in
Pics of the motor when i got it back from bill
Pics of the driverside quarter panel
Ported and polished
Gasket matched
5 angle valve job
Bisimoto Cam gear
B16 Throttle body
Bottom End-
Eagle H Beam Rods
)Tapped oil pan
ac and ps deleted
Trans-
S40 ex trans
7lbs flywheel
5 Speed Manual
Short shifter
Bad-
Trunk has 4 holes
xkrazyxjbrkerx75
Feb 9, 2013 01:16 PM
xkrazyxjbrkerx75
Oct 24, 2011 11:56 AM
xkrazyxjbrkerx75
Sep 14, 2011 05:35 PM
xkrazyxjbrkerx75
Apr 2, 2011 06:50 PM
xkrazyxjbrkerx75
Feb 2, 2011 10:58 AM
