OBD1 swap in obd2 shell w/obd2 boomslang with it pass inspection??
Old Jan 28, 2011 | 10:13 AM
TwotoneC1Da9's Avatar
Default OBD1 swap in obd2 shell w/obd2 boomslang with it pass inspection??
Before I bribe someone to pass my car illegally I wanted to check my options...
I have a OBD1 swap for a 96 shell and saw this:http://nipponpower.com/product.phtml?p=775
If I get an OBD2 ecu to plug it into will it pass? CEL will prob pop up fast right? This **** confuses me......
Old Jan 28, 2011 | 10:50 AM
baller status's Avatar
Default Re: OBD1 swap in obd2 shell w/obd2 boomslang with it pass inspection??
You still wont have the OBD2 diagnostic port.
Old Jan 28, 2011 | 11:24 AM
GSR CRX's Avatar
why would you get a CEL if your using an OBD2 ecu in a 96 shell? 96 shell is an OBD2a so the ecu wouldnt be a problem unless you removed all of the emissions equipment or you removed all of the emission plugs?
the DLC should still be there unless you removed that too.
using the OBD1 conversion harness will work and not give you CEL but it will probably fail you
at smog if they look since you are downgrading its emissions components.
Old Jan 28, 2011 | 11:34 AM
I have a completely obd1 gsr swap, whe I plug in an obd2 ecu wouldn't it look for the extra obd2 sensors that aren't there?
If i have an obd2 car why wouldn't it have an obd2 port....
BTW I live in NY if that means anything
Old Jan 28, 2011 | 12:02 PM
GSR CRX's Avatar
yeah your right. which one did you plug in? the on the exhaust manifold or the one on the catalytic? i suppose you can just plug in the other o2 and just zip tie it out of the way but that will give an off reading with no CEL. i never had an OBD setup like that so i dont really know how performance or emissions would suffer if any.
Old Jan 28, 2011 | 02:03 PM
I've worked at a few shops with obd2 theres no visual inspection other than lights and maybe tires and wipers if they want to make money.
I just spoke to someone from boomslang and he pretty much said completely convert everything or do it illegally, he even said don't buy their obd1 to obd2 jumper and just do a complete conversion...so much for that lolol
Thanks for the input tho guys next build I do I'll match my OBDs
TwotoneC1Da9
Northeast
Oct 13, 2010 08:38 AM
turbogsr18
Apr 28, 2008 10:37 AM
tour de france turbo
Sep 21, 2006 05:22 PM
