Suspension/swaybars
Old Jan 27, 2011 | 08:06 PM
H22aEHhatch's Avatar
Default Suspension/swaybars
Ive been told many different things about sway bars on an eg hatch I was told that ITR sway bars 25mm front and 23mm rear will fit on a hatch. But then I've also been told there's no way they will fit....has anyone tried installing them on an eg hatch? Or is it true that they don't fit....thanks a lot before i buy them lol
Old Jan 27, 2011 | 11:51 PM
NotAJDMFanBoy's Avatar
Default Re: Suspesnion/swaybars
The rear bar will fit, I have one installed. It's recommended to get an ASR or F7 brace. There are more accounts of subframe tearout on 96-00 Civics, but the 92-95 wasn't designed for this thick of a bar, so...
The front bar, just get a regular Civic bar. A lot of people prefer either no front bar or a thinner front bar to make it a little more tail happy. The understeer created by a thicker front bar is considered safer, but whatever you do, get used to it before driving spiritedly.
Old Jan 28, 2011 | 01:57 PM
98civdx's Avatar
Master Detailer
The front sway bar WILL fit.
EG/DC suspension is perfectly interchangable.
You just need integra lower control arms.
The rear will bolt as well.
A asr is reccomended.
Old Jan 29, 2011 | 06:24 AM
I knew that most dc stuff is interchangeable I just wasn't sure about ITR
Old Jan 29, 2011 | 07:14 AM
98civdx's Avatar
Master Detailer
Default Re: Suspension/swaybars
It's Basicly the same car, just a few suspension differences, but everything will basicly bolt right on.
Old Jan 29, 2011 | 07:44 AM
tlarimer's Avatar
I've got the ITR rear bar with ASR brace on my EH3 right now, no fitment issues. Kept the oem Si front sway bar, I like the feel better with this setup.
Old Jan 29, 2011 | 05:29 PM
So I have a vx which didn't come with front or rear sway bars so I would need to get gsr front and rear LCA's right? That's all I need for them to bolt up?
Old Jan 29, 2011 | 05:50 PM
tlarimer's Avatar
IIRC yes on the front and rears, don't forget the endlinks too.
I have the rear LCA's if you want, pm me.
Old Jan 29, 2011 | 07:12 PM
98civdx's Avatar
Master Detailer
Yep, You will need lca's. You can use ANY integra LCA, they will all bolt up.
Old Jan 29, 2011 | 07:52 PM
93egSLEEPER's Avatar
A asr is REQUIRED
Fixed. You are very likely to tear your subframe out with rear sway bar upgrades.
Old Jan 29, 2011 | 08:47 PM
So ASr is a must for the rear. Thanks! Any must haves for the front? Other than the lca?
Old Jan 31, 2011 | 12:35 PM
98civdx's Avatar
Master Detailer
I dont agree that a ASR is a must for you. I personaly know of several people runing ITR rear sway bars on both EG and DC's without any problems. They do get road raced and autoX'd quite a bit in the summer.
EG/DC's have a thicker subframe then a 96-00. 96-00 is the one you really have to be carefull with, they dont like large sway bars without a brace.
It really depends on the sway bar you are looking at. 19mm and below, stock subframe all day, no problems. 19mm+ you should look into something, just to be carefull and just for peace of mind.
I personaly have never heard of EG have a problem with subframe tearout, only a few 96-00's. Your driving habbits also play a large roll in it.
YES, if I were you, I would get a ASR, but they arent required.
No, for the front end you wont need anything besides the LCA's, and of corse the sway bar hardware/endlinks.
With my sway bars, I run ES poly bushings for the sway bars and Blox adjustable endlinks. Both are cheeper than stock, and work just fine. Endlinks arent going to last nearly as long though.
Old Feb 7, 2011 | 09:56 PM
Hey 98civdx, I am planning to get some coil overs Togo along with the sways ....my buddy says that if I get ITR sways I have to get iTR lca's and coilovers.....how true is this or will any dc lca work?
Old Apr 19, 2011 | 09:56 PM
So I picked up f/r gsr sway bars ....installed ....rear went in perfect with stock gsr lca's the front however needed more massaging to fit the subframe. the D bushing barely clears on both sides. It's not a big deal but has anyone else had this issue?!
Old Apr 19, 2011 | 10:07 PM
98civdx's Avatar
Master Detailer
Ohh, Sorry I never saw you post that. No, you don't need ITR LCA's to use the ITR sway bar.
If you do get ITR LCA's you'll need ITR specific shocks.
Is there a arrow on the D bracket? If so, it needs to be pointed forward.
I didn't have any problems on my sway bar install, but I have 98.
Old Apr 20, 2011 | 02:48 AM
Libertariat's Avatar
Ek Forever y0!
Most autocrossers tend to consider a smaller front sway bar an upgrade. the 26mm bars are just too much once you get decent suspension modifications.
Edit: If you need integra rear LCAs for your swaybar, I've got a good condition set from my brake conversion you can have, $55 shipped
OEM quality, blox/skunk2 etc will just tear out.
Old Apr 22, 2011 | 07:08 PM
Yea I believe the arrows are pointed to the front......I'll check when I go to work, as for the rear lca I got dc2 oem ones... interesting info on the aftermarket rear lca, could you elaborate? TIA!
Old Apr 22, 2011 | 08:03 PM
98civdx's Avatar
Master Detailer
It's the bushings. The really do not last. Sure, there has been some people with good results with them, however the majority of the people who use the have the bushings fail rather quickly. The blox LCA's are much worse then skunk2 though. Skunk2 has a new bushing out that is supposed to be much better then the last ones. Blox has noithing. But they do sell replacement bushings, but they are crap just like all the others.
EH3 JR
10
May 21, 2009 01:53 AM
Mooneyes13
May 24, 2006 11:26 PM
lopaka07
Suspension & Brakes
Oct 6, 2005 12:54 PM
Forrest Gump 9
Sep 10, 2003 02:33 PM
