Rear Sway Bar for 88 civic sedan
Old Jan 27, 2011 | 11:45 AM
88browncow's Avatar
Default Rear Sway Bar for 88 civic sedan
Ive been looking around and I have found write up on putting stock sway bars on the ef sedan. But I am looking for someone who has done it with an after market sway bar.
which sway bar works the best?
what will I need to do it?
what modifications are needed?
you get the drill, so please help. thanks
Old Jan 28, 2011 | 09:48 AM
grandtheftauto's Avatar
Default Re: Rear Sway Bar for 88 civic sedan
i know you can use a crx sway or da sway i think they just bolt right up. im also looking for a sway, if i go to the junk yard today ill test fit some stuff there and let you know.
Old Jan 28, 2011 | 10:16 AM
88browncow's Avatar
Thanks. If I cant get a good answer for an after market sway bar I may have to go with a DA sway bar and see how I like that.
But I really want to use after market sway bars.
Old Jan 28, 2011 | 10:34 AM
Driven's Avatar
the rear end is basically the same across all EDs.
so, ST bar will work with the sedan. no problems whatsoever.
Old Jan 28, 2011 | 12:03 PM
88browncow's Avatar
awesome thanks. thats the bar I was looking into anyways.
Old Jan 28, 2011 | 12:23 PM
jaycorolla's Avatar
hey i did a look up on sway bars of the ef sedan and hatch.... going with after market really is a waste of money.... your better off with teh DA or CRX si bar... but you need to go with poly bushings for it... thats where the diffference will be felt... i had an aftermarket one on my car and changed to a stock DA and there was no difference between the sway bars and how they perform... if you have everything else done properly then you can save some money and headache and go with the stock ones...
Old Jan 28, 2011 | 12:28 PM
88browncow's Avatar
thanks. thats very good to know.
Old Jan 28, 2011 | 01:21 PM
Driven's Avatar
depends.
Front sway bar... for a sedan, I'd run the SI.
For the hatch/CRX, HF all the way...
Rear sway bar, definitely want a bigger bar and the ST is one of the, if not THE, best bar.
ST bar is also adjustable, which is very nice when tuning the suspension.
Old Jan 28, 2011 | 04:43 PM
88browncow's Avatar
I was thinking about going st all around for sway bars. would the st bar be too large for the front making for some understeer?
Old Jan 28, 2011 | 06:15 PM
Driven's Avatar
Yes. Just get the rear bar and call it a day.
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
remoer
Suspension & Brakes
May 20, 2008 04:45 PM
dj12oclock
Honda Civic (2006 - 2015)
Mar 19, 2008 12:19 AM
DarkBB4
Feb 1, 2006 01:16 PM
