Obd0 to Obd1 Gsr question
Old Jan 27, 2011 | 11:20 AM
ummda9guy's Avatar
Default Obd0 to Obd1 Gsr question
Ok, i have an Obd1 Gsr motor that im wanting to swap into my Obd0 Da integra. What all do i need to get my car running with the Gsr motor in it? All i have as of now is just the long block. Im not planning on swapping the motor anytime soon, its just gonna get built for boost. Im using my Ls cable tranny, can i also use the clutch from the Ls on that gsr motor? Just need to kno as far as wiring, ecu, mounts, etc. that i will need to make this work. If you need more details then just let me kno.
Thanks.
Old Jan 27, 2011 | 11:34 AM
teggi's Avatar
Default Re: Obd0 to Obd1 Gsr question
jumper harness for the ECU obd0 to obd1
new o2 sensor (4 wires)
annddd theres more to that that i cant remember right now
teggi's Avatar
Old Jan 27, 2011 | 11:37 AM
ummda9guy's Avatar
ok. if you remember more then just let me kno.
Old Jan 27, 2011 | 11:38 AM
teggi's Avatar
oh, you're going to need to extend the MAP plug too
Old Jan 27, 2011 | 11:47 AM
ummda9guy's Avatar
Ok, Thanks ^
Old Jan 27, 2011 | 12:52 PM
Creator's Avatar
The jumper harness will also provide a place to run the wire from the Vtec solenoid.
Old Jan 27, 2011 | 07:52 PM
sik96teg's Avatar
you will also have to wire up the dizzy connectors for obd1. Run the wire for the vtec solenoid of course. The 4 wire o2 and ob0 to ob1 harness like stated above. run wires for the knock sensor and i believe that is it.
Old Jan 27, 2011 | 08:48 PM
teggi's Avatar
you dont really need to rewire the obd1 alt, u can just use the old one
also, you can re use the old injectors
Old Jan 27, 2011 | 10:47 PM
sik96teg's Avatar
who said anything about an alternator.
Old Jan 27, 2011 | 10:58 PM
teggi's Avatar
lol my bad, for some reason i was thinking about the alt haha
but yeah the distributor has to be rewired, or get a jumper for that.
Old Jan 28, 2011 | 12:59 AM
ek4ther's Avatar
The clutch is different.
Old Jan 28, 2011 | 01:43 AM
HondaPartsHero's Avatar
Technical Hero
The fan switch wiring will have to be extended to the thermostat housing from the current location on the back of the block. You can just reuse your current injectors, just keep the resistor box connected.
Old Jan 29, 2011 | 05:31 PM
ummda9guy's Avatar
Dang lol i need like a diagram for this. As far as the clutch goes, i think my Ls one will work, shouldnt it?
Old Jan 29, 2011 | 05:33 PM
ummda9guy's Avatar
Oh and which wiring harness do i use? the one from my Ls or the Gsr one?
zapzach
19
Feb 24, 2012 10:35 AM
2_Envy
Mar 20, 2010 04:46 PM
jdmboi3278
Engine Management and Tuning
Jan 28, 2009 11:17 PM
xiong1001
Jul 13, 2008 02:13 PM
slammedz6ef
Dec 31, 2007 04:13 AM
