94 civic wire tuck need help
ok i want to do a wire tuck on my car 94 civic coupe ex need to know if or what people are doing with all the abs break lines and stuff under the hood just bc it doesnt make since to hide all the wires if you can still see all that crap under there is it ok to do away with it and will i need anything like block off plates or what . also im guessing know would be the time bc i have my motor out so i can replace it with a new one it a gsr swap thats was the motor i took out also if this makes a diff.
ok what ? doesnt help
i want to do a wire tuck i know ab this part for the most of it but under my hood has alot of extra break lines going to the abs breaking system this is on a ex disc breaks all the way around can i get reed of the abs break system well the car still break ok , do i need any block off plates for this to work also is it easier to do the wire tuck if the dash was out or is this not necessary .
Also, to remove ABS..I'm fairly certain you have to swap your brake system over to a non-abs system. Someone correct me if I'm wrong.
