TWEEE'S CLEANING OUT THE GARAGE FOR SALE THREAD!!!
Old Jan 27, 2011 | 08:24 AM
tweee's Avatar
Default TWEEE'S CLEANING OUT THE GARAGE FOR SALE THREAD!!!
All prices are OBO. Local pick up only. Cash only. Located in the south bay. PM works best. I have more stuff and will update again. Please bump if viewed. Thank you!
BNIB 1 rear Koni yellow shock $120
Fits Honda Civic Del Sol 1993-1997, Honda Civic 1989-1995, Acura Integra 1994-2001. This is the only item I will be willing to ship.
95 Integra radiator $50
OEM OBD2 bare B16 intake manifold $50
STR 68 mm B series billet throttle body $150
OEM map sensor and TPS included. Throttle position sensor is calibrated already.
Stock pistons and rods from a JDM B20B $10/piece
OBD2 GSR virgin P72 ECU $100
00 Civic SI USDM OBD2B ECU $100
BLOX water temperature gauge, sensor and adapter with hose installed $40
No name intake filter, 3” coupler $20
02-04 OEM RSX Type S upper half exhaust manifold $40
OBX rear lower tie bar $30
88-00 Civic
90-01 Integra
Front upper Megan Racing strut bar $50
98-01 Accord coupe
B series valve cover $50
Cut and stripped ready for paint
B series VSS $40
95 Integra steering wheel and airbag $100
99-00 Civic steering wheel in gray, no airbag $20
OEM passenger side 98-01 Integra headlight $100
No broken tabs
96-00 Civic coupe power mirrors in electron blue pearl $50
EDM EK coin pocket center console $50
Rockford Fosgate Prime component amp $300
BNIB 300W x 4
Kicker subwoofer amp $300
500W x 1 monoblock amp
Skunk 2 K Series Pro Series exhaust cam gear $180
EG/DC clutch pedal assembly $40
DSM side mount stock intercooler $100
Minor dings, still functions properly
JDM K20A Type R cams $200
Unknown mileage, cam lobes looks to be in good condition, stock cam gears included
88-89 CRX passenger side tail light $30
98-01 Integra black housing projector head lights $40 for the pair
No broken tabs
02-04 RSX Type S bare OEM intake manifold $100
P72 AC bracket $40
Stock DSM blow-off valve, good for homemade turbo kits
- Blow-off valve with charge pipe $50
- Blow-off valve without charge pipe $20
MSD distributor cap for GSR with wires to external coil and boot $40
Adapter flange to convert from 2 bolt to v-band flange for BOV $50
DC doors $40 for the pair
Bare doors, comes with glass. Moldings were welded, filled then primered. Driver side has a dent.
95 Integra fuel pump (not pictured) $30
SOLD!!!
OEM P72 GSR intake manifold with fuel rail and stock injectors. No throttle body, no IACV
A PAIR (2) Falken Azenis tires, 205/50/15
BLOX filter and velocity stack kit, BNIB 3” inlet
HONDATA S200 on P75 LS ECU
Skunk 2 PRO 2 cams
JG Edelbrock Victor X intake manifold
STR block guard for B20 block
Skunk 2 Pro series cam gears
BLOX fuel pressure regulator
CTR pulley with brand new belt
LS Vtec line kit
Driver side replacement Hasport mount
MSD ignition 6A with MSD ignition blaster 2 external coil
Work valve stems
Skunk 2 5 speed shift **** 10x1.5 mm
Benen stainless steel B pillar bar
Skunk 2 dual bend short shifter
Sprint Hart CPF's
PROTHANE polyurethane master bushing kit
BDL Industries fuel pressure regulator
08 Civic Si K20Z3 OEM camshafts
Benen stainless steel 3 pt strut EG/DC
94-97 Integra tail lights
Stock EF/CRX front forks
MSD ignition SCI
Old Jan 27, 2011 | 08:29 AM
LSVTEC408's Avatar
Default Re: TWEEE'S CLEANING OUT THE GARAGE FOR SALE THREAD!!!
bump
Old Jan 27, 2011 | 08:44 AM
iH8RICERZ's Avatar
BUMP for twizzlers If I still had my integra or was building another motor, I'd be all over those cams, cam gears, v-stack, TB, etc etc etc
Old Jan 28, 2011 | 01:25 AM
ThaLost0ne's Avatar
TTT
Old Jan 28, 2011 | 03:22 PM
tweee's Avatar
Friday bump!!! BUY BUY BUY!!!
Old Jan 30, 2011 | 12:06 AM
tweee's Avatar
UPDATED!!!
SKUNK2 SOLD!
HONDATA SOLD!
Old Jan 31, 2011 | 10:01 AM
tweee's Avatar
MONDAY BUMP!!!
Old Feb 1, 2011 | 10:28 AM
tweee's Avatar
UP!
Old Feb 1, 2011 | 02:41 PM
tweee's Avatar
Skunk 2 Pro Series cam gears back up for sale!
Old Feb 1, 2011 | 03:13 PM
Black-Ty [EG6]'s Avatar
bump
Old Feb 2, 2011 | 12:09 PM
tweee's Avatar
UP!
Old Feb 2, 2011 | 12:30 PM
pArAdOxsqUArE's Avatar
view bump
Old Feb 3, 2011 | 07:20 AM
tweee's Avatar
Thanks for the bumps guys. =]
Old Feb 3, 2011 | 10:17 AM
kelviiv's Avatar
pmd
Old Feb 3, 2011 | 12:47 PM
tweee's Avatar
Replied
Old Feb 4, 2011 | 09:43 AM
tweee's Avatar
TGIF!
Old Feb 4, 2011 | 02:37 PM
tweee's Avatar
UPDATED! ADDED DC SHAVED MOLDING DOORS!
Old Feb 5, 2011 | 07:31 PM
tweee's Avatar
VICTOR X MANIFOLD SOLD!
STR BLOCK GUARD SOLD!
ADDED BDL INDUSTRIES BNIB FUEL PRESSURE REGULATOR
Old Feb 7, 2011 | 10:15 AM
tweee's Avatar
Old Feb 8, 2011 | 09:53 AM
tweee's Avatar
SKUNK 2 PRO SERIES CAM GEARS SOLD!
BLOX FUEL PRESSURE REGULATOR SOLD!
Old Feb 8, 2011 | 11:51 AM
xtrafastcivic's Avatar
its not listed but do you have a 2004 prb k series ecu for sale?
Old Feb 9, 2011 | 08:21 AM
tweee's Avatar
Sorry I don't have that lol
Old Feb 10, 2011 | 07:34 AM
tweee's Avatar
=P
Old Feb 11, 2011 | 09:34 AM
tweee's Avatar
HAPPY FRIDAY BUMP!
Old Feb 11, 2011 | 10:52 AM
BiG Chris's Avatar
Bump for a baller
