87 Honda prelude si
Old Jan 27, 2011 | 05:53 AM
KOBO's Avatar
Default 87 Honda prelude si
I have a 87 prelude and its having problems bogging down when you go into the throttle. I replaced the fuel pump,fuel filter,main relay,and fuel pressure regulator,also the ECT sensor. Anyone have an idea what it might be.
Old Jan 27, 2011 | 06:14 AM
92civlude's Avatar
Default Re: 87 Honda prelude si
plugged cat?
Old Jan 27, 2011 | 07:47 AM
KOBO's Avatar
Didn't think about that. cause it goes fine and everytime you give it throttle it almost like it cuts out then goes.
Old Jan 28, 2011 | 06:46 PM
92civlude's Avatar
Secondary ignition.
Old Jan 28, 2011 | 07:06 PM
LUDEcidDream's Avatar
try to reset the ecu. could be the knock sensor crapping out too..
Old Jan 29, 2011 | 09:06 AM
92civlude's Avatar
I dont think the 87 has a knock sensor. A failed knock sensor wont cause a bogging down issue. Check the secondary ignition. Cap, rotor, plugs, and wires.
Old Jan 29, 2011 | 10:51 AM
lude72's Avatar
tune up
Old Jan 29, 2011 | 12:09 PM
KOBO's Avatar
How about the injectors being clogged. I've done all but the secondary ignition
frostwhite si
Jun 27, 2007 03:44 AM
SKDRCR
Jul 8, 2006 06:14 PM
cperry
Jan 4, 2006 06:48 AM
dcrbin22
May 20, 2004 05:50 AM
