97 lude h22a4 cuts off while driving
Old Jan 26, 2011 | 09:27 PM
jdm97lude's Avatar
Icon2 97 lude h22a4 cuts off while driving
ok i have a 97 prelude and of course it has the h22a4 engine and if the car is cold i can start it and it will idle high but when it warms up i can drive the car up the road and it will cut off if i push the clutch in i falls down to about 900 rpms and will try to stay there and then falls on down to 0 to 100 rpms and will cut off and when i try to crank it back its sluggish till i hit the gas and then it idles up but if i dont give it a little gas it will cut back off or idle very low any one have any ideas thanks...........jeff could it be my tps....
Old Feb 4, 2011 | 03:23 PM
rimsandthings's Avatar
Default Re: 97 lude h22a4 cuts off while driving
where is the idle set at?
Old Feb 18, 2011 | 05:52 AM
jorge c.'s Avatar
i gt a 99 ek coupe with h22a4 swap and it does da same thing i replaced the xternal coil and i worked fine then while drivin started to sputter now i turned it off for a whie and wen i turn it on the idle is at 0 and cuts off sound real rough too any ideas?
Old Feb 18, 2011 | 01:55 PM
SolScifen's Avatar
Could be the tps.
Have you cleaned out your iacv to see if that helps? Or it kinda sounds like something with your throttle body not givin it enough fuel.
Old Feb 19, 2011 | 06:15 AM
jorge c.'s Avatar
i changed the tps sensor, map sensor, cleaned my injectors,cleaned da iavc. i was takin a gud look at da manifold and da previous owner tried to shoot nitrous direct so i have four bolts drilled into da monifold. i finally gt it on and i rev it to 1.5 and it starts to idle im gona change da manifold to c if its jus an air leak dat i cant find
Old Feb 19, 2011 | 05:29 PM
prelude2.2vtec's Avatar
i used to have a probelm similar to your and this it what fixed my issue, take out your egr valve and clean all the carbon build up w/carb cleaner, while your at it dump carb cleaner in the port for the egr as well....after i did that on my prelude..it idled a lot better and stopped dropping the idle when you put in the clutch...btw there is a post on how to clean the egr ports on the manifold
Old Feb 20, 2011 | 08:48 AM
jorge c.'s Avatar
i took a gud look at did manifold and da people who had dis mmotor shot nitrous directly to da manifold so dey drilled four holes on it. it has a very bad air leak anybody t an h22 stoc manifold for sale?
Old Feb 20, 2011 | 09:26 AM
REDLUDE4WS's Avatar
this jorge c dude makes no sense its hilarious! hahaha... does it have a misfire? check engine light? tps doubt it, iacv maybe but doubt it, fitv would make it surge, when was the last time you replaced your fuel filter
Old Feb 20, 2011 | 10:19 AM
jorge c.'s Avatar
dis motor makes no sense..lol it thrws check engine but dats becauce i have no o2 sensor..dis motor was jus put in dis car to make it run dats it most of da sensors dnt have plugs cumming from da harness its a mess. this harness is a jdm b16 so everything is on the opposite side .but it is an air leak in da manifold
Old Feb 21, 2011 | 01:14 AM
jdm97lude's Avatar
thanks for the info it ended up being my intake bolts had vibrated lose from the head and it was sucking air around the lower intake gasket i just put a wrench on them and it works just fine now thanks.....maybe this will help lol
Old Feb 21, 2011 | 06:06 AM
jorge c.'s Avatar
i tighten da bolts dat suppose to b pluggin up those holes put a lil silicone on em and it works fine now
89civicstd
Nov 13, 2013 03:56 PM
SaLvAcIvIc97
Nov 15, 2007 08:23 AM
turbo Si
Jun 1, 2005 09:07 AM
Too_Funny
Nov 13, 2003 01:53 AM
