**Need info on B20z ina 94 integra Ls**
Old Jan 26, 2011 | 09:27 PM
Dual Cam Killer's Avatar
Default **Need info on B20z ina 94 integra Ls**
simple question and i hope i get a simple answer,lol. Ok, i have a 94 Ls and want to drop a b20z in it, but im not sure if its gonna cause probs being that the b20z is obd2 and my teg is obd1. How would i go about doin the swap? would i just have to use my ls dizzy and ls intake, or is it gonna be more than that? thanks for all the help guys.
Old Jan 26, 2011 | 09:38 PM
53JDMDC2's Avatar
Default Re: **Need info on B20z ina 94 integra Ls**
just did same swap.
just swap intake, dizzy, alt and use the valve cover and pcv that comes with the b20.
u might also have to replace the pcv hose so it fits.
everything else bolts up and then is plug in and go.
took bout 1 day. also dropped the engine and trans out/in the bottom.
Old Jan 26, 2011 | 10:25 PM
the pcv? like the hose that runs from the intake to the oil breather box, i guess thats what its called? (black box on the firewall side of the engine)
Old Jan 26, 2011 | 10:27 PM
ive got a/c too. will my ls compressor bracket bolt up to the b20z?
Old Jan 26, 2011 | 11:02 PM
53JDMDC2's Avatar
the oil breather box goes away. its replaced by a hose.
a/c bolts up no prob.
Old Jan 26, 2011 | 11:14 PM
EGeek's Avatar
id highly recommend going vtec with that z
Old Jan 27, 2011 | 12:00 AM
lol as much as id like to, im barely gonna have the funds for the b20z itself. i do have a gsr trans that will be behind it and full exhaust and a header, so shes gonna be pretty stout for a daily driver, im keepin my a/c so it wont be all that fast but it will hold its own im sure. now that weve caught that "rabbit", what u mean the oil breather box goes away?? There will be a huge hole in the block if the box isnt there right? i dnt understand
Old Jan 27, 2011 | 03:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
OBD2 B-series engines don't have the oil breather box. The PCV valve is mounted in the valve cover with a hose going to the intake manifold.
Old Jan 27, 2011 | 08:33 PM
53JDMDC2's Avatar
the hole in the block is not there on the b20 i did. i used the pcv that came with the b20 and put a new hose on it.
SyFi605
May 27, 2013 06:43 AM
jonyi27
Nov 2, 2012 06:31 AM
crxrj
Jul 26, 2008 01:27 PM
89 pos
Sep 23, 2005 06:14 PM
