Running rich jdm d15b. Kill switch install weird problem?
Old Jan 26, 2011 | 08:34 PM
Unphzd's Avatar
Default Running rich jdm d15b. Kill switch install weird problem?
So first things first i have a 1996 ek hatchback with a jdm d15b with 3stage vtech. Recently i have been getting around 25 miles per gallon which is horrible for a JDM d15b according to the specs. I do not drive hard nor do i try and race people. I most drive from home to school or home to gym which consist of only a couple of miles. i am getting around 209 miles on a 29 dollar gas fill up. What could be wrong? the only code im getting is cel 10 and i am planning to hard wire that later one and im pretty sure thats not what is causing me to run rich. My friend said try changing my spark plug wires since i never changed it since i got the sawp.
Second, i recently installed a fuel pump kill switch on the process i accidentally cut the green wire with the yellow stripe... (facepalm) so i had to re connect it with those crimp style connector and after cutting the right wire this time and wiring it right, i was successful as i thought so. I never test drove it after installing it. Couple hours later i drove my car to the gym and on my way there it felt weird... at first when i was stepping on the gas it would go then slow down then go then slow down so i decided to pull over to the side and turn off the car i turned it back on and it happened a gain couple feet later after that never again did it happen is that common after installing a fuel kill switch? and what was the green yellow striped wire that i cut? Also i felt like i lost a lot of power after driving it when it went back to normal...
Hopefully this isnt too long...
Old Jan 26, 2011 | 10:24 PM
Unphzd's Avatar
Default Re: Running rich jdm d15b. Kill switch install weird problem?
HELP PLEASEEE
Old Jan 26, 2011 | 11:21 PM
djslim23's Avatar
Hey bro, I know I've asked you before but you're still running the P2J ecu and getting 25mpg?
Old Jan 26, 2011 | 11:45 PM
Unphzd's Avatar
Yup haha sucks.... 25 is like.. HORRID im buying some ngk spark plugs see what happens my current ones are little rusty i guess. and idk what triggered it but i think im running richer than last time now ... might have been my kill switch that i installed:\
Old Jan 26, 2011 | 11:49 PM
djslim23's Avatar
Definitely solder that wire. I've learned to trust nothing but soldering. It's actually really easy.
Old Jan 27, 2011 | 06:12 AM
Unphzd's Avatar
How much would a soldering kit cost? cuz i dont really have one...
Old Jan 27, 2011 | 10:35 AM
djslim23's Avatar
A cheap one that would do the job, $20-30. You need the soldering iron, a sponge, the right kind of solder (i forget, just google it), flux, rubbing alcohol (to wash of the flux), and heat shrink tubing for best results.
DO/\/\O
27
Dec 11, 2010 10:10 AM
JDMFreak_DC2
Lighting
Apr 27, 2008 03:33 PM
R.S.
Aug 25, 2003 09:42 AM
aw1234dude
Jan 24, 2003 07:18 PM
FusionITR
Feb 9, 2002 12:56 AM
