I pulled the codes from the cel on my 95 civic d16
Old Jan 26, 2011 | 04:37 PM
tundra2000's Avatar
Default I pulled the codes from the cel on my 95 civic d16
Today i went out and checked my cel because it been on for awhile and it was a intake air temperature sensor that i got from it, now would that cause my idle to be kind of loopy? and could i just clean up the sensor?
I also checked my 94 hatch (which it didn't have a cel pop up but i thought i would check) and when i check it the cel stays on is that normal? it has a b20 turbo swap in it.
Old Jan 26, 2011 | 04:41 PM
Winlight's Avatar
Default Re: I pulled the codes from the cel on my 95 civic d16
I just had the same problem on my 96 civic but I didnt notich anything different when I fixed it other then no CEL.also the IAT was $28 after tax.
Old Jan 26, 2011 | 04:50 PM
Former User's Avatar
Is the IAT sensor unplugged?
That means no codes are thrown.
Old Jan 26, 2011 | 05:05 PM
tundra2000's Avatar
it's not unplugged, it's the sensor on top of the throttle body right?
Old Jan 26, 2011 | 05:17 PM
If you don't know where it is located, how do you know it's not unplugged? It's a two wire sensor plugged into the rear of the intake manifold.
TA sensor:
Old Jan 26, 2011 | 05:35 PM
tundra2000's Avatar
Yeah it's not unplugged but would u happen to know what color the wires are that go to it because i got another plug that laying around and don't know where it goes.
Old Jan 26, 2011 | 05:49 PM
Red/Yel and Grn/Wht
supercoy101
Honda Civic (2001 - 2005)
Jun 9, 2009 01:00 PM
supercoy101
14
Jun 7, 2009 10:46 AM
ten2doyle102
Feb 6, 2009 08:30 PM
Black Si
May 4, 2004 03:44 PM
