Valve cover screw tightening, broken now lol
Old Jan 26, 2011 | 04:28 PM
Einhander276's Avatar
Default Valve cover screw tightening, broken now lol
How many of y'all have done this and now have 3 screws holding down the VC? on a SOHC. what can be done to fix it? Oil keeps on fluding my damn spark plug #2...
Old Jan 26, 2011 | 04:32 PM
crxrocks's Avatar
Default Re: Valve cover screw tightening, broken now lol
Replacement with OEM replacements and buy a torque wrench.
Old Jan 26, 2011 | 04:44 PM
CRX Toad's Avatar
Get a pair of viced grips and twist the old one out and put OEM piece back in. If you haven't done the VC gasket and the spark plug tubes also do them to stop your leaks.
Old Jan 26, 2011 | 08:05 PM
tonythetuner®'s Avatar
Also if the bolt snaped off flush and you cant grip it with vg. Use a easy out and a drill bit
Old Jan 26, 2011 | 08:15 PM
b1u3_5i's Avatar
If the screws are flush with the cyl. head buy/borrow a left hand drill bit and extractor set. Clean VC and replace with a VC kit. Local part store will do, just dap it with RTV sealant and refill motor oil.
Old Jan 26, 2011 | 09:30 PM
rudyndrew's Avatar
I've stripped mine but never broken 1 off. Went to the junkyard and got it plus a clean vc gasket for cheap too cause I was leaking.
TunesEK
Jan 15, 2009 01:35 PM
krytykalintentions
May 4, 2007 05:41 AM
e_r_i_c_
Feb 15, 2006 07:08 PM
loup05
Jan 28, 2006 05:30 PM
combustion
15
Apr 11, 2005 02:53 PM
