stripped bolt/any other way to get trans fluid in?
Old Jan 26, 2011 | 04:07 PM
bad 91 teg's Avatar
Default stripped bolt/any other way to get trans fluid in?
bought new honda trans fluid .... so i tried to chage the fluid in my 5 speed...when i relized the top bolt is completely stripped. the bottom bolt (drain plug ),came loose just fine.but the top bolt you loosen do add new fluid is stripped ... any ideas i got a slight grind in second and ...really want to get the new fluid in . is there any other way to put fluid in besides the top bolt. i just bought the car so i have no idea where thr fluid level is!
bad 91 teg's Avatar
Default Re: stripped bolt/any other way to get trans fluid in?
thanx 4 any help ...im @ a loss?
Old Jan 26, 2011 | 05:19 PM
Eclectia's Avatar
How much access do you have to the top bolt? If theres enough room, you could try hammering a smaller socket onto the bolt head, or an easy-out.
Old Jan 26, 2011 | 05:37 PM
HondaPartsHero's Avatar
Technical Hero
What car do you have, just by going with your signature
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Old Jan 26, 2011 | 07:57 PM
netfreak's Avatar
Fill it through the reverse sensor hole. Much easier than trying to fill through the side (IMHO), and trying to fill it through the speed sensor at the very back is a lot of unneeded work. So yeah, you have the two above alternatives if you can't use the actual fill hole.
Old Jan 28, 2011 | 03:27 AM
Blown90hatcH's Avatar
VSS hole man. One bolt and super fast/easy.
Old Jan 29, 2011 | 05:37 PM
bad 91 teg's Avatar
thanks alot everyone ..thought i was dead in the water.lol what is vss hole ? speed sensor ? and i need to locate it.
Old Jan 31, 2011 | 09:53 PM
allmotorlsbaby's Avatar
or you can fill through the breather cap hole take a while but gets the job done if in a bind if all the others listed wont work
Old Feb 1, 2011 | 09:20 AM
TheAsian's Avatar
X2 for the speed sensor.
Its located on the back on the trans right above the passanger axle on the top of the case. One bolt and its out. Make you you take the bolt out that mounts to the trans. If its hard to pull out turn it around a few times.
Also as stated above you could fill through the vent tube but its a slow process especially of your fluid is cold.
Old Feb 1, 2011 | 10:23 AM
m_shake's Avatar
speed sensor hole is the way to go!
Old Feb 1, 2011 | 04:09 PM
bad 91 teg's Avatar
so glad i posted this question. just recently bought this ..and 2nd barely grinds? i hope with the honda fluid it will fix it... i have no idea how old the fluid is ? SO THANK U EVERYONE . this helped me out alot..
blk600cc13
34
Apr 10, 2020 04:56 AM
thiscivicuser
Feb 26, 2008 06:13 PM
ocdcivic
Dec 11, 2004 10:11 AM
2lobes1engine
26
Jun 29, 2004 08:27 PM
Too_Funny
Nov 8, 2002 03:34 PM
