92 Accord Ex Wagon Engine Vibrates
Hi, I am a newbe here but have been lurking around for awhile. Need some help. The engine in my wagon vibrates the keys in the ignition when you come to a stop w/ your foot on the brake. I have already replaced the rear engine mount (back of engine by fire wall) and the "torque rod" (front of engine by cooling fans) and inspected both other mounts. This made a big difference but it is still not right! As i have 2 other Honda f series engines to compare it to. A 95 F22B6 w/ 237k and a F22B1 W/ 207K on it. Both of which are smooth as silk no vibrations what so ever! I have done a complete tune up on it plugs, wires, cap, rotor,pcv valve, cleaned the egr passages and replaced the egr valve. Any thoughts are welcomed. It has 107k on it
Thank You
Joe
Thank You
Joe
seems like you've tried about everything already... my only thought is to check the balance shaft timing. this is very involved but with 107k miles you're about due for a timing belt "package" anyway if you haven't done this already.
Thanks
Joe
I had a vibration I could never figure out, and did all the obvious things you did. Then my alternator failed, after replacing then alternator, to my surprise no more vibration.
Thanks
Joe
zoomhonda
Jun 30, 2010 08:37 PM
