Heater core question
For the guys that removes/eliminate their heater core. Once the heater core is removed do you guys bypass the hose by closing them shut or run one long hose from the back of the block to the head?[*]
Depending on what the OD of the coolant hose you use will be, you can buy either steel braided tubing or a long steel spring that you trim to length and you slip over the hose, this allows you make nearly 90* bends on a dime without collapsing the hose. This way you can just buy ~3ft of straight hose and do what you please with it.
Frost_1097
Jun 5, 2007 10:21 AM
coot_er
May 14, 2004 01:52 PM
