can you use an obd0 distributor on obd2? swap bogging, help.
Old Jan 25, 2011 | 06:29 PM
iheartjayDem's Avatar
Default can you use an obd0 distributor on obd2? swap bogging, help.
hey ht. I had an obd0 b18a in my ed6 & I blew it up so I replaced the longblock with an obd2 b18b. I reused my complete ob0 intake manifold, ecu, dist, ect ect. The car starts up and idles fine but when you try to drive it kinda backfires and bogs. I had to plug the hose from the iac because it went to the back of the obd0 block that I'm not using, could that be an issue? I don't have a cel & I'm pretty stumpedd. Thanks.
Old Jan 25, 2011 | 10:13 PM
TheJunBuilt's Avatar
Default Re: can you use an obd0 distributor on obd2? swap bogging, help.
what ecu are u using .. ignition timed correctly
Old Jan 26, 2011 | 06:30 AM
obd0 pr4 & yes. i read somewhere on here that obd0 distributors have a 16tooth crank sensor while the obd 1/2 distributors have a 24. can anyone confirm this?
Old Jan 26, 2011 | 09:40 AM
tonythetuner®'s Avatar
no a obd0 ecu can not run a obd1/2. Dizzy. And yes as the obd0 dizzy has 16 tooth crank sensor and the obd1/2 dizzy have a 24 tooth. And the the reason it will not work
Old Jan 26, 2011 | 10:42 AM
I reused my obd0 pr4 & obd0 distributor (td24u)
Old Jan 26, 2011 | 01:45 PM
bumppp, someone on ht has to know what's going on -__- lol
Old Jan 29, 2011 | 09:51 PM
process of elimination
88EDHatch
Nov 12, 2010 11:27 AM
VegasInvasion
Jul 1, 2010 10:49 AM
TurboAngst
Dec 2, 2007 10:29 AM
EF9ZC
12
Mar 8, 2006 04:59 PM
Maddox
10
Apr 11, 2004 11:24 AM
