Valve adjustment cost?
Old Jan 25, 2011 | 05:04 PM
Killspeed93's Avatar
Icon2 Valve adjustment cost?
iv been doing my research and noticed that its not extremely difficult to adjust the valves. My valves are ticking on the cover and id like to fix it, but i dont want to risk it and would rather have a pro work on it and not make it worse. Around how much would it cost to get the valves working properly again? rough estimates?
Old Jan 25, 2011 | 05:10 PM
TunerN00b's Avatar
Default Re: Valve adjustment cost?
Around $300 for an independent shop. I believe (but no not exactly remember) something like a $650 quote from the dealer for it.
Or, it's around $45 for a nice feeler gauge and a new gasket to do it yourself.
You sure the ticking you're hearing isn't the injectors? My engine clicks like valve ticking, but my valve lash was still correct when checked at 40k miles, and still correct at 70k miles (when I last checked). They've never actually needed any adjustment, but the injectors can be easily heard.
Old Jan 25, 2011 | 05:13 PM
s14civic's Avatar
a valve adjust from a dealer should be more than a couple hundred for a 4 cyl
Old Jan 25, 2011 | 06:18 PM
MD426's Avatar
Non-vtec is very easy, there is a special tool for lash adjustment for vtec engines or you can make your own, google it if you need it. $20 feeler gauge and some patience. I also have a tick, checked all the lash tolerances and they were dead on.
Old Jan 25, 2011 | 06:23 PM
dc2LS's Avatar
I also need one id be nice if there was a DIY on here.
Old Jan 25, 2011 | 06:48 PM
Targa250R's Avatar
be professional
Do people seriously pay that much? Holy crap. Are you sure you aren't thinking of a timing belt service?
Our shop charges $70 + gaskets to check and adjust valve lash for DOHC 4-cyl engines, and $64 + gaskets for a SOHC 4-cyl.
Most engines don't need much in the way of adjustments. Some B-series and J-series heads are susceptible to tightening exhaust valves, which don't make noise but can cause problems if not adjusted.
Some minor ticking is normal, especially on a cold start-up. Another common cause of valvetrain noise is a low oil level . . .
Old Jan 25, 2011 | 06:50 PM
sayanything's Avatar
you should def, do it yourself. Learn about how your car works, AND save a TON of money. I just did this for the first time about a month ago and it was very simple. i just google searched it and the cspeed racing write up looks pretty good.
Old Jan 25, 2011 | 08:40 PM
53JDMDC2's Avatar
id need more info. but not a big deal. hit me up
Old Jan 25, 2011 | 08:59 PM
MD426's Avatar
I could write a DIY, im pretty sure there is one somewhere though. just search in google, Integra valve lash adjustment. Maybe a DIY with pictures for non vtec would be nice.
Old Jan 26, 2011 | 11:40 AM
TunerN00b's Avatar
Nope, I called a few different local shops, and that was the average quote I was given for a GSR. I would hope a non-vtec would be cheaper.
That was when I discovered my current preferred shop. They charged $120, which still seems a bit steep for no actual adjustment, but then went and deducted half of that from other work.
Anyway, I'm probably in a somewhat uncommon scenario, living in LA (close enough anyway) and with a condo complex that forbids any automotive work on the property. I've had the retarded old women in the complex call security because I was outside changing a flat tire before...
Old Jan 26, 2011 | 11:45 AM
mouab18c1's Avatar
Originally Posted by Dogginator
Actually, I'd do it for free if the individual truly wished to learn.
This! But if I have to freeze my *** doing it in the winter better be getting me some Carl's JR afterwards LOL
Old Jan 26, 2011 | 11:56 AM
87g1teger's Avatar
ill do it for $100 here at the shop were i work at (Cerritos Acura) we do it for about 160...
Old Jan 26, 2011 | 01:16 PM
Targa250R's Avatar
be professional
Cliffs: Southern California professional labor rates.
$120 is about right if they're working on a $100-110/hr labor rate, which isn't uncommon for densely-populated urban areas. Most non-coastal regions in the US have lower rates.
Old Jan 26, 2011 | 01:57 PM
TunerN00b's Avatar
Thanks. I'm a bit verbose at times.
Old Jan 26, 2011 | 01:59 PM
N/A's Avatar
N/A
Purpose Built
You guys are getting raped.
I could name 4 different shops in my area that would do it 60-70$
Old Jan 26, 2011 | 05:15 PM
so i think the best bed would be for me to do it myself then i assume... will leaving it alone for a while affect the car much,? its not too loud of a tick and tends to go away as i drive its more on the idle than anything but i dont want to hurt the motor its my dd
Old Jan 26, 2011 | 05:35 PM
N/A's Avatar
N/A
Purpose Built
LS engine have been plagued by that valve tick, its nothing abnormal just refrain from revving it up high untill you do the adjustment
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
supersize
Jul 26, 2010 11:50 PM
kornerk12
Dec 18, 2005 03:27 PM
GSRVTEC1
Oct 31, 2005 01:19 PM
