2007 Odyssey A/C functionality issue. What is right?
We have a 2007 Odyssey that we are trying to figure out how the AC is suppose to function.
The issue is: We expect the rear A/C vents to run at the temperature that is set by the drivers settings, if the "rear on" button is enabled & and the "Rear lock" button is enabled.
I read the manual and it confirms that when both buttons are enabled, the rear a/c vents should run at the drivers temperature.
But our experience has been that the temperature of the rear A/C vents runs at the temperature set of the rear A/C control panel regardless of what buttons are enabled.
Does anyone know if this is how it's supposed to work or is our system defective?
Rosss
Jul 14, 2017 09:53 AM
