Swapping stock b20 into stock 00 ls integra!!Questions
Old Jan 25, 2011 | 12:20 PM
Ridncln's Avatar
Default Swapping stock b20 into stock 00 ls integra!!Questions
Looking to swap my 1.8 with a b20...anyone know if everything swaps over or anything special that has too be done? plz lmk thanks
Old Jan 25, 2011 | 05:07 PM
Ridncln's Avatar
Default Re: Swapping stock b20 into stock 00 ls integra!!Questions
???Anyone
Old Jan 26, 2011 | 11:26 AM
92db2gs-r's Avatar
you just gotta put your ls intake manifold on the b20, use your ls bracket for driver side mount, and id reccomend chipping your ecu with b20 specs so your motor dont run lean.
Old Jan 26, 2011 | 11:42 AM
mouab18c1's Avatar
You don't need to have a chipped ecu if you are just keeping it stock. When running a chipped ecu an ls basemap is used as a base and from there you would need to tune it. There is no such thing as b20 specs.
Old Jan 27, 2011 | 08:40 PM
53JDMDC2's Avatar
u dont have to really tune the ecu. i was recomended an adjustable fuel pressure regulator. but the only thing i can think of is that if is a jdm b20 u need to find out how to deal with the missing crank sensor. i know its been done just havent done it myself.
Old Jan 27, 2011 | 09:40 PM
92db2gs-r's Avatar
he needs a b20 basemap because his motor will be running too lean plus the redline on the b20 is probily different.
Old Jan 28, 2011 | 07:08 AM
hbcrazy88's Avatar
if you say probably in there, you probably dont know.... LOL. the both redline at 7.
Like stated before just get a FPR
Old Jan 28, 2011 | 09:30 AM
mouab18c1's Avatar
There is no such thing as a b20 basemap. Do some research before posting.
Old Jan 28, 2011 | 12:53 PM
98bucket's Avatar
you just gotta put your ls intake manifold on the b20, use your ls bracket for driver side mount.
yup. thats it. it will run great, what year is it?(b20)
i put a 99jdm b20 in my DA and it runs like a champ, i took out a Lexus Is300 with it(stock). and me and my girls brother put one in her 94' teg and it also runs good.
no chipping, tuning needed.
Old Jan 28, 2011 | 12:57 PM
98bucket's Avatar
yeah. the FPR is optional.
Old Jan 30, 2011 | 09:13 PM
el vtec monster's Avatar
agreed my b20 in my da9 swapped in clean...all i changed out was my intake maifold cuz its bigger and wont fit..how ever it flows smoother once u change it...u can put the b20 ecu if u want but it isnt needed...
Old Jan 31, 2011 | 12:10 AM
monsterCHILD's Avatar
dON'T WORRY...... 2.0L and 1.8L differ only a little bit. I have a B20 in my 90 DB1, WITH MY stock YS1 cable trans.. Also just put a A/F gauge and I can see why I am lean. But when it is warming up it IS super RICH. So if you want better gas millage tune the ECU for extra .2L. Hondata S300 is the way to go, data logging while the car is racing.....
Old Jan 31, 2011 | 09:57 AM
mouab18c1's Avatar
You can datalog with any EMS besides the first version of Crome.
Old Feb 7, 2011 | 06:08 AM
gRim06's Avatar
i was considering a jdm b18b swapped for my a1 and heard somewhere that the ports on the b18b head are slightly larger and that port matching may be helpful.
I have since strayed toward the B20b and i was thinking, would the ports be larger on it too? or is this even true to begin with?
i was thinking about the running lean situation as well and considering its a bigger displacement and because of the larger flow intake im running causing my a1 to run lean anyway, somehow, i never thought about or i guess i didnt know about the adjustable FPR, but its a good idea, burnt valves suck!
Old Jun 3, 2018 | 12:40 PM
Henryh's Avatar
you didn't have to change the distributor? And what about the knocking sensor? How did you wire that on 00 ls teg?
Old Jun 4, 2018 | 07:54 AM
CandyRedRC46's Avatar
This is a 7 year old thread. Can you go be a one post wonder somewhere else?
bettsbanger
Sep 19, 2009 12:09 PM
jimmysteezen757
Jul 28, 2009 08:10 AM
jdm91CrxSi
Sep 26, 2007 07:55 PM
troppop
Jul 30, 2006 04:04 AM
