dpfi d16y7
Old Jan 25, 2011 | 08:16 AM
KINGVEM^^ED6's Avatar
Default dpfi d16y7
so as some of u know im putting a y7 in my ef
dont have the right intake mani
need the car to run TODAY
will i have any problems running a dpfi IM on the y7
Old Jan 25, 2011 | 08:19 AM
Default Re: dpfi d16y7
i could give a fvck about hp
just need this **** running
Old Jan 25, 2011 | 08:31 AM
alex14's Avatar
provided that your DPFI dizzy will fit on the car, I dont see why not.
Old Jan 25, 2011 | 09:02 AM
yeah i have a 91 hatch
Old Jan 25, 2011 | 09:15 AM
alex14's Avatar
i know the DPFI dizzy wouldnt bolt up to my Z6 head, so make sure the DPFI dizzy will bolt up to the B7 head, as the B7 is a OBD1 motor.
Old Jan 25, 2011 | 10:09 AM
Datunnerkid's Avatar
In any case u i think you can use youre stock ef head on the y7 block.
Old Jan 25, 2011 | 03:53 PM
efjones9's Avatar
Yea it will work
Old Jan 25, 2011 | 04:01 PM
HondaPartsHero's Avatar
Technical Hero
Yeah it'll bolt up. The only real difference will be the fan switch is on the thermostat housing on the Y7 and on the back of the block of the D15B1. Your distributor will bolt right up to it.
Old Jan 26, 2011 | 08:31 AM
efjones9's Avatar
but again, it will run like dog **** because of the timing differences between obd2 and obd0
Old Jan 26, 2011 | 08:54 AM
its not even getting spark
cel is on no code FML
Old Jan 26, 2011 | 09:04 AM
efjones9's Avatar
reset the ecu. did u do mpfi or stayed stock
Old Jan 26, 2011 | 09:08 AM
stayed dpfi and i will
but why wouldnt i get spark
Old Jan 26, 2011 | 09:13 AM
efjones9's Avatar
its probably something easy lol. check grounds check connections. when i dont get spark i would just tighten up the ground on the head and the thermostat housing and most of the time its that
Old Jan 26, 2011 | 09:22 AM
yeah thats what i was thinking the same ima have to extend the thermostat housing wires that ground whole is cracked well see thanks again brah
Old Jan 26, 2011 | 07:45 PM
netfreak's Avatar
If you used all the old stuff on the Y7, there would be no problem. I did exactly this last year and am still running it. The only mod really was ghetto rigging something to deal with the coolant hose at a different angle and extending the temp sensor wire.
Old Jan 26, 2011 | 09:40 PM
Clipsed's Avatar
Wiring guru here fixed his car. This can get lockkkked I wont put vem on blast in this thread :p
Old Feb 3, 2011 | 02:53 PM
Sweet!!! so wut was the prob yo?
Old Feb 3, 2011 | 03:00 PM
bad ground
its mpfi now :D
jdm.swift
Sep 25, 2010 01:23 AM
4g4dcruisin
Jun 21, 2010 06:37 AM
big_daddy234
Oct 6, 2009 11:42 PM
todubbled1
Feb 1, 2009 09:02 PM
shbrown
May 12, 2005 04:36 PM
