wanting a nice flush look.
Old Jan 24, 2011 | 05:58 PM
91efbluehatch's Avatar
Default wanting a nice flush look.
i am wanting to go with a nice flush/ offest look when it comes to some car shows.
kind of the look that i am going for.
what all would i need??
LCA's, wheels with nice offset, camber kit.??
Old Jan 24, 2011 | 07:30 PM
M&Ms's Avatar
Default Re: wanting a nice flush look.
do know much about the hellaflush thing but i know alot of people run wheel spacers to get the look they want
Old Jan 24, 2011 | 07:38 PM
i know a little about hella flush, never really researched it.
i know that i am going with some nice Diamong Racing wheels, just for the nice off set, and look.
Old Jan 24, 2011 | 09:11 PM
Scott53092's Avatar
It all depends on the wheels and offset, lower offset the more they stick out away from the hub. Oem wheels are about +45 offset. As you get lower offset you'll need to roll your fenders and want to have them pulled out some. Rims that are like 15x8s with around +20 offset can usually be ran on a low car while getting away with just rolling the fenders, but you'll need to throw a good amount of neg camber on it. Sharp turns or even turns with bumps will probably cause some rubbage, I couldn't do u turns well. As you get down to +10 or +0 offset fitment becomes a challenge, and lots of negative camber is in the works. And with wide rims and low offset you can't run wide tires, so you have to stretch the tires to fit, some people are against it but as long as it isn't a ridiculous stretch it is fine.
Old Jan 25, 2011 | 01:05 AM
godluvstegs's Avatar
you need to roll your fenders and i suggest stiff *** suspension or **** is going to be hitting for sure
Dipsett
Nov 4, 2012 09:54 AM
1PT-SICK
Honda S2000
Aug 23, 2010 06:20 AM
treezilla
Acura TSX
14
Oct 17, 2008 06:19 PM
nyrican23
Apr 18, 2008 10:36 PM
hi mom
Feb 14, 2004 01:07 PM
