B18B OBD2 to OBD1 Question
Old Jan 24, 2011 | 03:28 PM
zcoffey's Avatar
Default B18B OBD2 to OBD1 Question
ok im kinda new to honda-tech. my friend jimmy told me to post up a thread about a problem im having. I searched but didnt find the answer i was looking for. I have a 96 integra with a b18b obdII p75-c03 ecu. Im wanting to convert to obdI and run my p75-A01 ecu to get rid of a few sensors.everytime i hook it up my idle bounces and then dies if i dont give it gas any ideas how to fix?
Old Jan 24, 2011 | 03:38 PM
fcluddington's Avatar
Default Re: B18B OBD2 to OBD1 Question
try being a little more detailed what exactly are you asking.
Old Jan 24, 2011 | 07:12 PM
zcoffey's Avatar
my question is when i hook up my obd1 ecu my idle bogs and bounces then eventually dies if i dont give it gas. how can i fix the idle problem?
Old Jan 25, 2011 | 05:05 AM
start with the usual. check timing, what condition are plugs, wires in. did the car just start doing this when you switched ecu's or did u switch hoping to fix it. what rpm does it "bounce" up to. or would it be better to say it's struggling to stay running and dies. when was the last time the car ran right or is this how you bought it.
Old Jan 25, 2011 | 06:36 AM
Mindgamez's Avatar
Try Using an ODB1 TPS sensor.
Old Jan 25, 2011 | 08:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why do you want to get rid of sensors? I don't see a point to converting to OBD1 if this is the original engine/ECU in your car.
Old Jan 26, 2011 | 06:24 PM
zcoffey's Avatar
the timing is good and so are the plugs and wires. the car runs fine with the obd2 ecu. i just want to get rid of the crank sensor and the extra o2 sensor and stuff. and yes it struggles to run unless i give it gas. a friend of mine told me to take my throttle body off and screw some screw in that was under it?? does anyone know what he might be saying? thanks for the help by the way
Old Jan 27, 2011 | 03:59 AM
So if it runs fine with the obd2 ecu. do u have a diff. car to check out the obd 1 ecu to make sure it works. I have taken a obd1 ecu and with a jumper harness plugged it into my b18b and i couldnt tell a diff. i only let it idle but is it possible their is something wrong with the ecu you are trying to use.
Old Jan 27, 2011 | 06:42 PM
94EG8's Avatar
Seagull Management
It's exactly the same as an OBD2 TPS sensor.
Unless you're planning on getting it chipped and dyno tuned it's complete waste of time and money.
My thoughts exactly.
Old Jan 28, 2011 | 05:38 AM
Send the obd1 ecu to one of the sponsors on the HT they can check it out. Next time post in the engine management section. do not waste money putting a stock b18b on a dyno. The idle adjustment is on top of the tb under the brass plug.
Sprocksilvia
14
Jun 23, 2010 09:59 AM
soodominican
Jan 17, 2009 01:25 PM
Dackonn
Dec 13, 2007 12:55 PM
Cameron60
May 3, 2007 09:59 AM
7808
Apr 16, 2007 09:36 PM
