Can Ecu's go bad???
Old Jan 24, 2011 | 03:21 PM
gceniceros209's Avatar
Default Can Ecu's go bad???
Sup lude dudes. Yea, I think my p13 is faulty because my car feels really shityy when driving normally but it hits vtech like a monster. So currently its hooked up to a p14 which makes it run fine but it feels like 140 hp instead of the 190 that the h22 puts out. I have h22 injectors so this leads me to beleive that the p13 ECU might be messed up
Old Jan 24, 2011 | 03:26 PM
TaffetaEj6's Avatar
Default Re: Can Ecu's go bad???
it may very well be a faulty ecu. the first swap i bought had a faulty pw0 ecu, and my expierience was pretty much what you just described.
-I
________________________
ej1 b16a sir 1 gsr trans chipped rpt p28 i/h/e *sold*
ej6 b16a sir 2 ls trans virgin jdm p30 ecu i/h/e - I have a ls trans...why am i not boosted yet???
Old Jan 24, 2011 | 03:29 PM
minilogoguy18's Avatar
Don't start guessing though, before you even consider buying one find someone you can swap ECU's with and see if your car runs better.
Old Jan 24, 2011 | 03:52 PM
Thank you, someone actually replied. I bought the car with h23 injectors in the motor which is why it was hooked up to the p14. I got the rite injectors and hooked it back up to the p13 but it rides shitty. If i can find someone who will lend me ther p13 i will definetly test run the car
Old Jan 24, 2011 | 04:14 PM
jrod90dc2's Avatar
i dont know anything about ludes but my guess would b if the injectors r different maybe the fuel pumps r different too. just something to look into. is there any cel's? any chance it might b in limp mode?
Old Jan 24, 2011 | 05:17 PM
No cel's, just abs light on. When hooked up to the p13 it runs super shitty at low rpm's but it comes alive above 4 1/2 rpm. Rite now its hooked up to the p14 ecu and it runs fine but vtech doesnt engage. That why i think it has smething to do with a faulty ECU.
Old Jan 31, 2011 | 10:35 PM
Alrite so i found that my first cylinder is misfiring when hooked up to the p13 which is causing it to run shitty. This doesnt happen with the p14 which means that the engine is confused wen hooked up to the p13. I think the dude before me messed up on the swap and didnt change the dizzy or something
Old Feb 2, 2011 | 09:46 PM
problem solved. Got a new ecu and the car runs great.
Old Feb 3, 2011 | 08:17 AM
mike541's Avatar
Old Feb 7, 2011 | 02:01 PM
TaffetaEj6's Avatar
woot woot
accord13
Jan 8, 2023 03:51 PM
PremiumPrelude
Mar 12, 2008 01:25 PM
The Weather Man
Sep 28, 2005 10:22 AM
IN10SITY
May 24, 2004 02:06 PM
ndo125
Nov 1, 2001 10:50 AM
