Honda CR-V & Element 2WD & 4WD Element & CR-V
Error Code p1399pd for 2000 CRV
Old Jan 24, 2011 | 06:42 AM
Natron1's Avatar
Default Error Code p1399pd for 2000 CRV
Hello all, I am having some problems with my CRV. I just replaced a cracked valve, the timing belt, the head gaskets, and some seals on my crv. Now I is still throwing error codes saying all 4 cylinders are misfiring and I is giving me the errror code p1399pd this code is not in the chilton manual please help. Thank you!!!
Old Jan 24, 2011 | 11:32 AM
Jaker's Avatar
Default Re: Error Code p1399pd for 2000 CRV
Have you driven the car since the work was completed? How does it run?
Old Jan 24, 2011 | 02:05 PM
Natron1's Avatar
It does not run smooth, it occasionally bucks. Does not Idle steady either. Thanks for the reply I hope that helps...
Old Jan 31, 2011 | 12:00 AM
pd0019's Avatar
1399 is a general misfire code. i would take it back to the shop and have them check everything again. timing might be off, they may not have adjusted the valves. to me, with all that work they must have left something loose or something.
Speed Kills
Aug 14, 2010 09:59 PM
BoltonGSR
Audio / Security / Video
Feb 21, 2007 03:05 PM
ReggieGrip
Feb 21, 2006 05:00 PM
Bh8teen
Aug 31, 2005 09:26 PM
nighttime
Jul 7, 2004 04:15 AM
