Wanted : Sleeved H22 Block
ive got a h22a sleeved block with 90mm bore. less than 10 passes on it. bores are in perfect shape and can be bored to 91mm if desired. comes with main caps oil pan arp main studs balance shaft elimator kit new oem honda oil pump. already clearanced for h2b if you are running that. let me know!
