Resistor Box Needed In 89 Si ?
Old Jan 23, 2011 | 01:16 PM
93grayeg's Avatar
Icon2 Resistor Box Needed In 89 Si ?
Im getting ready to swap my B20b back into my ef , somehow the resistor box got misplaced. Is it needed to put in my swap and have it running? I know I needed it when I was boosted....
Thanks
Old Jan 23, 2011 | 01:40 PM
xXxRed FoxXx's Avatar
Default Re: Resistor Box Needed In 89 Si ?
It depends on what injectors your running.
Low impedence require a resister box. Check your injectors with a multimeter for resistance... if it has 2-3 ohms its low impedence. Also known as peak and hold.
Old Jan 23, 2011 | 02:03 PM
93grayeg's Avatar
Its just the stock b20b injectors. not sure what they are
Old Jan 23, 2011 | 02:14 PM
homebuilt503's Avatar
If your using the stock b20 injectors you shouldn't need the resistor box. Just dont forget to wire the connections together from where the resistor box used to plug into
Old Jan 23, 2011 | 02:28 PM
93grayeg's Avatar
I dont think there are any wires? just a plug where the factory resistor box plugged in
Old Jan 23, 2011 | 02:35 PM
yea that is what i meant. that plug where you plugged the resistor box in, those wires will need to be connected.
Old Jan 23, 2011 | 03:34 PM
tonythetuner®'s Avatar
Wat he means is all the same color wires on the injector plugs mean the yellow and black stripe all get connected to one single wire and the single wire you connect to the the yellow and black wire for the resitor box plug
Old Jan 24, 2011 | 04:42 AM
92egvx's Avatar
im going to need to figure this out too
dk=gsr
Engine Management and Tuning
Mar 6, 2012 11:20 AM
_kiid
Jun 8, 2009 12:57 AM
mpf90
Mar 23, 2009 11:54 AM
BoostBoi
Nov 13, 2004 11:50 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
