Honda CR-V & Element 2WD & 4WD Element & CR-V
Help honda CRV engine feels slugish low rpms and about 3k etc. higher smooth?
Old Jan 23, 2011 | 12:42 PM
EG-SIXV-TEC's Avatar
Default Help honda CRV engine feels slugish low rpms and about 3k etc. higher smooth?
A neighbor asked me if i can tune up his 99 honda CRV and i say ok and asked why?
he said that about a year ago he let someone to do a tune up spark plugs wires etc??
its a manual transmission and for a week he noticed a change.
he says when ever going uphill or some flat surface the engine feel like its slow and hesitant when driving or in low speed rpms, shifting gears
when in highway or etc its smoother.
i test drove it and it felt like it was slow engine weak or somthing in the beginning, like wtf, 1k to 3k about and then like power kicked in later.like vtec kick in when its smooth lol but its not vtec. it felt smoother but in the low rpms it feels like slow lacking power. sometimes like when shifting to another gear the engine feels lacking power or something.
up hills it feels worse, when test driving later the engine light came on. he said that it didnt do it before.
pls help..
Old Jan 23, 2011 | 12:47 PM
eghatch4sale's Avatar
Default Re: Help honda CRV engine feels slugish low rpms and about 3k etc. higher smooth?
it has a bad valve !!!!!!!!! its firing on 3 cylinders ..... pull one plug wire off at a time to test each wire should change the way it idles except the one that is not firing .....
Old Jan 23, 2011 | 01:11 PM
but if i remove one wire that is bad, that meaning its the 1s that its not firing would the engine already supposed to be running bad already diff even if i didn't remove it??
idk because the enigne feels like its idling smooth when only at idle but when driven it feels like its loose power?
Old Jan 23, 2011 | 04:39 PM
Targa250R's Avatar
be professional
Check the cam timing, ignition timing, and valve lash.
Old Jan 24, 2011 | 07:40 AM
EL Vap133's Avatar
What code did it throw?
nonoyc
Oct 9, 2017 04:07 AM
gtimax
Aug 29, 2011 05:00 PM
fitzov
Jun 21, 2004 04:48 PM
strils
Dec 28, 2001 07:52 AM
