Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission knocking on acceleration
Old Jan 22, 2011 | 06:28 PM
95_Civic_4dr's Avatar
Default Transmission knocking on acceleration
'95 Civic EX 5-speed.
I have a knocking noise coming from the transmission. Does it when starting from both 2nd and 1st and continues until about 10mph or engine RPM reaches 800-1000rpm then just goes away.
Occasional grinding from 1st to 2nd under hard acceleration.
I was wondering what bearing(s) it could be if it is a bearing issue. I did have my input shaft bearing go out and replaced that, when I had the case split at the time the other bearings looked good (year and 1/2 ago).
Old Jan 22, 2011 | 07:14 PM
94EG8's Avatar
Seagull Management
Default Re: Transmission knocking on acceleration
Sounds like a bearing issue, other mainshaft bearing or the outer countershaft bearing is most likely what's bad, but it's impossible to know without pulling it apart.
Old Jan 25, 2011 | 10:26 PM
So if it was only knocking in the forward gears but not reverse, would it be a bearing on the counter shaft or main shaft? or could it be either one?
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
civic ef
May 29, 2012 01:02 AM
superfast666
Jun 6, 2008 10:41 AM
zman
Aug 22, 2004 08:41 AM
