HELP!! IAT sensor...does this one look bad? pics inside..
Old Sep 24, 2002 | 02:27 PM
92TypeR's Avatar
FSAE
Default HELP!! IAT sensor...does this one look bad? pics inside..
My car throws CEL 10 (IAT sensor). So I figure I should check to see if the sensor is bad before I assume its my wireing job. The end of the sensor looks like it has been either melted, or blown out..? I'm not sure what to make of it, and I have no real comparison. If anybody can tell me if this sensor looks good or bad, please reply ASAP!!
PICS:
Any help is greatly appreciated...
[Modified by 92TypeR, 3:27 PM 9/24/2002]
[Modified by 92TypeR, 3:46 PM 9/24/2002]
[Modified by 92TypeR, 4:13 PM 9/24/2002]
Old Sep 24, 2002 | 02:33 PM
tonyxcom's Avatar
Default Re: HELP!! IAC sensor...does this one look bad? pics inside.. (92TypeR)
looks pretty jacked to me!
Old Sep 24, 2002 | 03:10 PM
92TypeR's Avatar
FSAE
Default Re: HELP!! IAT sensor...does this one look bad? pics inside.. (tonyxcom)
I agree...
Also, is the IAT a model specific sensor...as in...can I buy one for, lets say a Civic Si, just because the Acura dealership around here charges way too much...or should I only get the IAT sensor for a '00 ITR?
Old Sep 24, 2002 | 03:12 PM
Smitdog's Avatar
Default Re: HELP!! IAC sensor...does this one look bad? pics inside.. (tonyxcom)
Yep
Old Sep 24, 2002 | 03:13 PM
92TypeR's Avatar
FSAE
Default Re: HELP!! IAC sensor...does this one look bad? pics inside.. (Smitdog)
BTW the topic title has IAC instead of IAT ...just incase some of you are confused...
Old Sep 24, 2002 | 03:44 PM
92TypeR's Avatar
FSAE
Still trying to figure out if this part is interchangeable...does anybody here know?
Old Sep 24, 2002 | 03:47 PM
tonyxcom's Avatar
I would assume that it is interchangeable. It takes a temperature reading, and the temperatures that it should read should be relatively even.
Tell you what.
I am going to go and do some majic on Majestic honda and Carland acura and get the REAL HONDA part numbers for you. Please dont ask me how I do it, because I will not tell anyone and ruin it for myself
Old Sep 24, 2002 | 03:49 PM
sneakychaos's Avatar
IM a moderator and have them change it for you.
Old Sep 24, 2002 | 03:52 PM
92TypeR's Avatar
FSAE
Tell you what.
Thanks
Thanks
tonyxcom's Avatar
Default Re: HELP!! IAC sensor...does this one look bad? pics inside.. (trooth)
The part number at Acura is 37880-PE2-013
BUT the SI's sensor is located on the intake arm. Which means it is probably the same as the CX, DX which doesn't screw in.
Basically, you got no choice but to get it from acura.
Old Sep 24, 2002 | 03:53 PM
yoshi234's Avatar
I shoot brides
done
Old Sep 24, 2002 | 03:55 PM
Tony the Tiger's Avatar
Default Re: HELP!! IAT sensor...does this one look bad? pics inside.. (92TypeR)
I agree...
The '99 Civic Si (SiR in Canada) uses a different IAT sensor that mounts on the intake tube... that means it won't interchange. You will need to either buy a GSR IAT or the ITR IAT.
Old Sep 25, 2002 | 09:20 AM
79 civic's Avatar
you had too much power to the sensor. Sensor voltage is only 4.5 volts, and having 12 volts to the IAT will melt the end of the sensor.
Fix your wiring
Old Sep 25, 2002 | 09:22 AM
79 civic's Avatar
Default Re: HELP!! IAT sensor...does this one look bad? pics inside.. (79 civic)
Go to the junkyard and pick up a IAT from any 92-95 civic for much less than new.
integrag
Mar 9, 2008 09:56 AM
scarface50370
Dec 3, 2005 09:05 PM
satan_srv
Dec 5, 2002 05:12 PM
navin
May 28, 2002 10:39 PM
