crank position sensor problem
Old Jan 22, 2011 | 03:32 PM
crxsi814's Avatar
Default crank position sensor problem
Ok my 90 crx si keeps coming up with code 4 I have tried new dizzy and ecu and I can't figure it out can anyone help.
Old Jan 22, 2011 | 03:49 PM
tonythetuner®'s Avatar
Default Re: crank position sensor problem
Check the wiring. If you have a ecu pinout. On plug c is where the wires are for that sensor. C1 will be blue with green stripe and c2 will be blue with yellow stripe they both run to the dizzy. Your wiring is most likey messed up between the ecu and dizzy you can look for brakes or shorts in the wire and fix them or just run new wires from c1 and c2 to the dizzy
Old Jan 22, 2011 | 03:55 PM
crxsi814's Avatar
Ok could it also be where the pins are on the ecu connector because I'm having problems with my injectors for cylinders 1 and 3 I checked resistence it was fine on all four it was the same so I ran a new wire for injector 1 and 3 and it didn't fix it but I noticed that the pins were loose could I go get a dpfi connector from a dx and just re pin it like it should be for the mpfi or won't that work thanks for the help I'll check the wires for the crank position sensor thanks for the help just getting closer to getting my project done and more problems show up and I'm also new to the crx
Old Jan 22, 2011 | 04:02 PM
Yes loose pins at the ecu can cause bad conection. And yes you can use a dpfi ecu Plug to take new pins from and repin them to yours. also besides code 4 do you have any other codes
Old Jan 22, 2011 | 04:28 PM
crxsi814's Avatar
16 and 41 my o2 sensor isn't connected I will get a pic tomorrow of my jumper harness I don't know where my o2 sensor wires up to so I will get a pic of that for you tomorrow and mayne you can help me with that also
crxfreak1117
Nov 28, 2007 05:56 AM
soulconfiguration
Dec 19, 2006 11:50 PM
civickid03
Jul 25, 2006 03:02 PM
Blaze45
Dec 13, 2003 06:28 PM
WhiteDSM520
May 5, 2003 04:03 AM
