ITR Bin File (Crome)
Old Jan 21, 2011 | 02:40 PM
Mr. EG's Avatar
Default ITR Bin File (Crome)
I was looking for a BIN file for my setup which consists of...
JDM ITR 96 Spec
3 inch AEM CAI
Hytech Rep Header
BCS2 Exhaust
AEM Fuel Rail
AEM ADJ. FPR (what psi should this be set at?)
Stock Cams, Stock Internals
ECU: P28 chipped
I appreciate any help.
Old Jan 21, 2011 | 03:04 PM
Mr. EG's Avatar
Default Re: ITR Bin File (Crome)
All Motor just helped me out with a Map. Thank you very much!!
Old Jan 21, 2011 | 03:33 PM
Mr. EG's Avatar
Here was the map given to me by All Motor if anyone else needs it http://www.mediafire.com/?vujwpb3ebb3ece9.
Old Jan 21, 2011 | 03:34 PM
mtber's Avatar
There is not a "stock ITR" bin for Crome.
You can use a stock p72 bin & tune from there.
My suggestion is to get a binary file from a respected tuner/vendor on the forum.
We along with other vendors offer them.
Old Jan 21, 2011 | 03:36 PM
mtber's Avatar
Put a wideband oxygen sensor gauge on your car when you are running that map & get back to us...
The ignition tables also could use adjusting.
Old Jan 21, 2011 | 03:37 PM
Mr. EG's Avatar
Isn't a P72 map fairly different from a P73 considering an ITR has a higher CR, Larger cams, a factory port, and a different style IM (No IAB's either)?
Old Jan 21, 2011 | 03:38 PM
mtber's Avatar
I didn't say it was similar. I said to use it as a starting point.
Old Jan 21, 2011 | 03:39 PM
Mr. EG's Avatar
Will do. I trust All Motor and that map was for a setup similar to mine.
Old Jan 21, 2011 | 03:40 PM
Mr. EG's Avatar
What should my fuel pressure be set at?
Old Jan 21, 2011 | 03:54 PM
mtber's Avatar
Maybe you should ask him :-)
Like I said, put a wideband on the car...
Old Jan 21, 2011 | 04:15 PM
Mr. EG's Avatar
It will have one.
Old Jan 21, 2011 | 06:41 PM
mouab18c1's Avatar
Someone has joke's. LOL
Old Jan 21, 2011 | 09:35 PM
Mr. EG's Avatar
It was stock fuel pressure BTW, I can take a joke its all good.
Old Jan 22, 2011 | 05:44 AM
mtber's Avatar
Wasn't a joke. By simply looking at the VE curve of the high cam fuel map posted I do not believe it is going to hit target lamda. Not every car is the same, however 90% of the them are similar in ve curvature.
Old Jan 22, 2011 | 09:06 AM
Mr. EG's Avatar
So your saying your map for an ITR with bolt ons and stock inkectors at a stock fuel pressure would differ from this map?
Old Jan 22, 2011 | 10:29 AM
mouab18c1's Avatar
For a base it would work, but again every modded car needs a tune.
Old Jan 22, 2011 | 10:53 AM
Mr. EG's Avatar
Yes I know, I will play with this map a bit. Generally a bolt-on ITR will be pretty darn close to my bolt-on ITR.
Jimmynitro
Engine Management and Tuning
Sep 30, 2012 02:13 AM
BoostinEJ1
Jun 7, 2006 02:26 AM
slowteg550
May 4, 2006 07:26 PM
rice4life
12
Jan 5, 2005 05:27 PM
metal-x
Apr 17, 2003 01:17 PM
