oil cooler removal
the reason i'm doing it is that i do oval racing on a 400m track and at most about 7-8 laps, i'm figuring that my oil temp will not be a problem but getting it up to temp is, also will it help oil flow with it removed?
how did you do it, i was thinking of getting a 22mm threaded nipple to just screw into the centre then using a filter with 22mm thread, i think a cherokee has one, i presume you put your cooler take off plate directly onto the block.
thanks for the replies
hi mate, the reason i'm planning on removing it is that its a bit of a restriction on oil flow, also if you get an engine failure like i have it will be full of crap. i really dont need it as i'm only doing short races and my prob is getting the oil hot enough not keeping it cool, i think it will just simplify things
