B series shift linkage ?
Hey guys well I'm planning to swap a ls motor into my 89 civic hatch...i need a shift linkage for my swap and i know that i could buy one like Avid or Innovative but i have a 93 da shift linkage i know i read something about being able to cut a DA shift linkage somewhere about 2 inches in the straightess part and weld back together and it will bolt right up and have no problem...has anyone done this and wat are your opinions one this, reason why i ask is because im broke i have a son and i rather put him first than my project car...just trying to save a little extra cash but if its bad i'll just wait and save to buy a aftermarket one...thanks for the input fellas..
ive heard of people who have welded them, i havent heard any bad things. if i was me tho id just save up and buy aftermarket one. thats what i did and i havent had a single problem out of them. just make sure u get good mounts, i had crapy mount on my swap when i first did it and broke the back mount, ended up twisting the linkage all up
Hear is a good link on modding the da shift linkage to work! http://www.performanceforum.com/wesv...r/shifter.html. credit to wes vann's
most mount kits you can use DA linkage but it needs to be shortened by 2 and 3/8" for it to work. with the motor mounted in the car, just mock up your DA linkage before you cut it and you should be able to measure how much you need to shorten it. remember to shorten it ONLY in the spots where the shift linkage is straight and not on a bend
it really depends on what mounts you are using... i had JDM SiR linkage with old school early 90's HAsport mounts and i shortened mine by 2 and 1/4". i would try to google it
Fo-Do Fanatic
11
Feb 15, 2011 11:10 AM
hatch_kidb18b1
May 6, 2009 06:39 PM
