Sacramento Moving Sale. Very cheap parts
http://sacramento.craigslist.org/pts/2171815367.html
-2 300 watt sub amps, brand new sealed in box. One still has 79.99 price tag on it, $20 each
- 6 brand new in box car alarms, 2 remotes, adjustable shock sensor, good solid security alarms, (not keyless entry though) - $15 each or $50 for all 6
-Lot of 9 brand new boost/vac gauges, each comes with hardware and mounting bracket. -$8 each or $40 for them all
-Turbo starter kit for civics. (Can easily swap the manifold so you can add one to fit a different car). Has a great shape garrett turbo, (Either a .42 .48 or a slightly smaller one, your choice), wastegate, hf manifold, new boost gauge, some misc charge piping, a box full of silicoln couplers and clamps, obd1 chippable ecu, ecu chip kit, some other oil lines can be added in. -$175
-Turbo, great shape garrett turbo, with internal wastegate either a .42 .48 or a just slightly smaller one (person getting kit has first choice). $40
-3 12”x12” boxes of civic and integra ecu’s. Obd0, obd1, and obd2 ecus, have some p06 p05 about 20-25 ecu’s total. - $100 takes them all, plus 10-15 ecu chip kits. (also have ecu chip kits for $10)
-box full of new ultra bright led lights, individual leds for custom setups. All sort of colors, and uv, some multi color flashing ones as well. About 700 leds and 700 resistors and 50+ 9v clips, 50+ small metal or chrome led mounting clips- whole box and setup for $20
-5 new mtx fuse distribution blocks, hold 4 agu fuses. (msrp about $35) $5 each, or $15 for all of them.
-4 new Rockford Fosgate agu fuse packs (each has 4 agu fuses) $2 each, or $6 for all of them
-7 20’ tsunami new RCA interconnect wiring. $2 each, or $8 for them all
- new Rockford Fosgate fuse distribution block, holds 4 agu fuses $7
-new Lightening Audio 1 meter RCA wiring. Bolt OFC series, high quality, $3
-new Rockford Fosgate 1 meter RCA, stealth twisted series, top of the line, $3
-100+ 9v connector clips with ~6” wires -all of them $4
-Civic 2 piece cold air intake (can be used as a short ram, or piece added and used and a cold air intake, not carb approved) Comes with nice cone washable filter. $25
-civic d series 88-00 2 piece header, 4-2-1 design. Stainless, and a great way to add a little mid range and top end power to your d series. Great shape, just not carb legal. -$25
-y8 motor, that needs a rebuild or for parts. Just the block, and lower half, no head. -$20
-y7 intake manifold, throttle body and some sensors, and fuel rail and maybe injectors? -$20
-sohc transmission from ex, needs a rebuild $10, comes with the vss too.
-sohc civic clutch plate and pressure plate, appear to have decent life left I believe, $10
-Acura Bose cd player, single din, fits integras and civics as well. Works well and you can get a higher end stereo that looks like a stock one for cheap. It is actually even setup to run pre-outs to amps. $20
I need to sell everything this week, I am in south sacramento and you will have to come pick up any items you are interested in.
Ohh and if you are interested please contact me through craigslist. I am primarily interested in cash. I think the only trades I may consider are possibly a set of 15" or 16" wheels and tires or a very nice musical keyboard, or a digital piano.
Dorby
Jan 4, 2007 06:41 PM
dohc-nyne
Sep 14, 2004 09:15 PM
