91 Civc Help
I have a 91 Civic D-15, and I am having a problem starting it after shutting it off and say running into a store. It always starts in the morning (cold), but if I drive somewhere and turn the car off it will not start. The motor will crank 3 or 4 times and the check engine light comes on but will not start. The only way to get it to start is to crank the motor 3 or 4 times’ then turn the key off and back to start in one move. This will start the car most often, but if it just will not start I will have to let it sit for like 20mins and it will start. This sounds weird and doesn’t happen every time. I don’t know what is wrong so I have gone through with a tune-up replacing plugs, wires, cap, rotor, oil and this is still happing. I am asking you guys because I’m lost and could use any good ideas of what to look into. Thank you for your time!
RogueScribe
Jul 16, 2007 04:28 PM
DAVID_VARNER
Aug 8, 2006 03:23 AM
datbuoylex69
13
Dec 12, 2002 08:43 AM
