Help! quick question about installing ITR sway bar w/BSQ kit
Old Sep 24, 2002 | 01:14 PM
JDubya's Avatar
Default Help! quick question about installing ITR sway bar w/BSQ kit
I went to bretts site but i was a little confused at about hitting that nut off. does anyone have any pix? and then on step 12. That longer bolt and flange nut, do i need to buy these? or what? please help, asap. i wanna get this done tonight. and yes i searched...
Old Sep 24, 2002 | 02:39 PM
JDubya's Avatar
Default Re: Help! quick question about installing ITR sway bar w/BSQ kit (Hybrid Teg98)
So no one has used the BSQ kit? com on...its gonna get dark soon....ahhhh
sorry, i'm a little ancy, i want to put it on.
Old Sep 24, 2002 | 04:04 PM
JDubya's Avatar
Do i need to knock off both welded-on nuts from the top and bottom mounting hole on each side? or just the bottom one thats behind the ABS bracket? and what longer bolt and nut do i used for the bottom mounting spot?
Old Sep 24, 2002 | 04:47 PM
JDubya's Avatar
ohhhhhh, those 2 bolts and flange nuts were on the parts list from Acura, i didn't see them well i dont feel like waiting to go to the dealer so would just regular bolts and nuts from the hardware store work fine? or do i have to use the Acura bolts and flange nut? and i just need to knock out the lower nut right? not the one on top?
Groove_D
Suspension & Brakes
Mar 20, 2007 06:29 PM
SoCal EJ1
Suspension & Brakes
25
Dec 30, 2006 01:03 AM
ctownintegra
Suspension & Brakes
May 16, 2006 11:30 AM
MAD GSR
Suspension & Brakes
May 15, 2005 03:54 PM
BolivianDc2
Sep 28, 2003 07:03 PM
