Spoolin Performance Garrett Turbo Kit Complete Part Out
Old Jan 20, 2011 | 01:51 PM
xlasianizelx's Avatar
Default Spoolin Performance Garrett Turbo Kit Complete Part Out
NO Low ballers, this set up cost me well around $4000.. these are all name brand parts NOT EBAY STUFF HERE
Included:
Spoolin Performance Log Manifold (A/C, P/S Compatible) - $400 w/ Downpipe and Dumptube (Retails for $650)
Spoolin Performance 3" Downpipe w/ Flex Tube - only sold w/ manifold
Spoolin Performance Dump Tube - only sold with manifold
ATP Turbo Oil Lines (feed and return) - $50 (retails for $120)
XTD Racing Intercooler (minor damage but works fine) - $75 (minor damage on bottom, works fine - Retails for $150)
Custom 2.5" Intercooler Piping for Integra (fits my civic del sol also) - $125 (Retails for $210)
Tial 38mm Wastegate - $190 (retails for $225+ extra springs ($30 each) (7lbs installed w/ spare spring w/ different settings)
Garrett 50trim turbo - $350 (paid $700 at atp, have reciept, turbo smokes a bit only when its warming up, no shaft play could use some new seals but still spools fast)
Greddy Type RS Blow off Valve (hidden in wheel well) - $175 (retails for $230)
Greddy Electronic Boost, Oil and Fuel Pressure Gauges ( 3 52mm gauges) - $300 (retails for $189 EACH)
Greddy Air Fuel Ratio Guage w/ o2 sensor (JDM 60mm) - $150 (Retails for $200+ w/o o2 sensor)
Apexi Turbo Timer - $50 (retails for $90+)
Blox Filter Sandwich adapter - $25 (retails for $30)
Blox Vacuum Manifold - $25 (retails for $40)
B-Series Tapped Oil pan - $50 (avg $50 for used pan + $40 for fitting and labor)
Venon 550cc injectors (no resistor box needed, cleaned and flowtested) - $200 (retails for $300 on summit)
Tune Chipped on Crome by Ryan at tech3 - $150 (avg ecu $100 + $400 for tune) (made 200whp / 190wtq) at 3000rpm on a smaller t3 turbo which only maxed out at 200hp (was never able to find the time to get it retuned with the 50trim turbo)
etc. (theres probably more not listed but its complete)
this kit is complete, needs nothing, just a retune / flash and your good to go..
this kit is A/C and Power steering Compatible..... if you were to price everything out, you would see that its well over my asking price..
asking $1400 FIRM, no low ballers, (will only trade for wheels + tires for s2000 fitment or s2000 hardtop, or s2000 coilovers)
http://sfbay.craigslist.org/search/p...inAsk=&maxAsk= check out this link for other items..
(415)272-6744
Old Jan 20, 2011 | 08:56 PM
Default Re: Spoolin Performance Garrett Turbo Kit Complete Part Out
bump
Old Jan 21, 2011 | 09:00 AM
Bump
ruskipunker
Apr 27, 2011 04:52 AM
holset b18c
Nov 22, 2009 08:52 AM
ForceFed Motorsports
Jul 21, 2009 07:34 AM
blackANESE
Dec 11, 2008 08:53 PM
SoldMyEM1
Sep 3, 2005 01:02 PM
