Transmission & Drivetrain Gearboxes, Differentials, Clutches
integra CMC swap. in need of thread size
Old Jan 20, 2011 | 12:52 PM
tekstyle's Avatar
Default integra CMC swap. in need of thread size
does anyone know the hydraulic port thread size for the stock integra CMC?
i am replacing it to a tilton and need to get the correct fitting. the tilton is a 3AN female and it came with a 3AN male to male straight fitting and a 3AN male to female straight fitting.
I was planning on using a banjo and bolt type attachment. however in this forum http://cl.acurazine.com/forums/showt...php?p=12321289, this one guy used a 3an ended banjo with a 10mm x 1.0 bolt to hold it in place.
the second thing I want to know is if a 3AN is the same as 10mm x 1.0 bolt. would I be able to use a 10mm x 1.0 bolt and a banjo on a tilton CMC with a 3AN output port?
Old Jan 22, 2011 | 01:15 AM
tekstyle's Avatar
Default Re: integra CMC swap. in need of thread size
anyone? someone must know!
DB8_TEG
Oct 24, 2003 04:03 PM
Dan GSR
Oct 25, 2002 06:40 AM
