Transmission & Drivetrain Gearboxes, Differentials, Clutches
j1 Transmission, possible LSD! need opinion
Old Jan 20, 2011 | 12:07 PM
Shut It Fool's Avatar
Default j1 Transmission, possible LSD! need opinion
I just bought a J1 transmission and the guy claimed it was LSD. According to my research the J1 never came with LSD, BUT when i look through the hole where the axles go through, its a straight-through hole with no "bar" or "pin" in it, which means it is an LSD, correct? It looks like there is a smaller gear in the middle instead of the "bar". Its nothing like i've ever seen before.
Old Jan 20, 2011 | 05:53 PM
Aquafina's Avatar
Default Re: j1 Transmission, possible LSD! need opinion
Pics? If you can't see through its not an LSD (unless its a Wavetrac which will have a solid plate when you try to look through.
Old Jan 20, 2011 | 06:10 PM
the pics wont show for some reason... look at the crx/ef forum and check "ef yu" 's post, thats the pic
Old Jan 20, 2011 | 09:07 PM
Aquafina's Avatar
OEM viscous LSD.
Old Jan 21, 2011 | 04:01 PM
THANKS! What transmission would this be out of? whats the pros/cons of this type of LSD?
Old Jan 21, 2011 | 04:36 PM
Aquafina's Avatar
It's an option in a lot of JDM transmissions.
Pros: It's an LSD
Cons: Doesn't work well, weaker than a helical LSD, permanently turns into an open diff if it gets hot (at that point it needs to be replaced)
Old Jan 21, 2011 | 11:57 PM
Thanks. What is the best oil to use in this transmission? in your opinion
Old Jan 22, 2011 | 12:26 PM
Aquafina's Avatar
Torco MTF
Old Jan 22, 2011 | 01:45 PM
redzcstandardhatch's Avatar
something different
could easily permanently turn to a spool too...seen that happen to a number of older diffs in jdm cable b series trannies.
Old Jan 23, 2011 | 09:08 AM
Pros: It's an LSD
can it be directly swapped out for a quaife?
Old Jan 23, 2011 | 11:52 AM
Aquafina's Avatar
No, you will need to change the final drive out as well.
Old Jan 23, 2011 | 06:55 PM
For which transmission would i need to get a final drive out of? how can i tell if the existing viscous type LSD is working before i install it on my car? thanks a lot for the info by the way. appreciate it
Old Jan 23, 2011 | 07:14 PM
Aquafina's Avatar
No way to tell really, it has a sealed center section.
You would need a FD from either a GSR/ITR, LS, or B16. GSR/ITR for a B18C LSD and LS/B16 for a B16A/B18A or B LSD.
Old Jan 24, 2011 | 05:32 AM
Is there any difference in the material/strength of these gears compared to that of an s1 or a1 integra LS transmission? I keep going through 3rd and 5th gears on stock motor power. I'm doing a mild boost setup in the near future too, b16a built on 15-20psi, would the stock j1 be able to handle this? If not what gearset do you reccomend?
Old Jan 24, 2011 | 11:17 AM
Aquafina's Avatar
Not sure. I'd go ahead and change out to a large spline trans (92-93 for cable transmissions).
Old Jan 24, 2011 | 07:46 PM
large spline? what exactly is the difference between a 92 vs a 91 teg transmission?
Old Jan 25, 2011 | 07:27 AM
99SiStyle's Avatar
I'm searching the same question too. Trying to figure out if an OEM helical LSD will fit in a cable trans. Don't really want to convert to hydro, but looks like i might have to.
Old Jan 25, 2011 | 11:35 AM
Aquafina's Avatar
The shafts (main and counter) have a larger OD and the gears have a larger ID on the 92+. Both are smaller on the pre 92.
Old Jan 26, 2011 | 04:51 PM
thanks for your help
89ED
Dec 26, 2013 12:21 PM
Shut It Fool
10
Jan 21, 2011 03:59 PM
jazmie
Feb 1, 2010 10:20 PM
HondaPH22
Nov 23, 2006 12:52 AM
1998 Hb
Aug 23, 2004 05:44 PM
