WI FS:EG LX Sedan B16 swap
From: behind the dumpster, w./your bitch, w./your bitch
1995 Honda Civic Lx 4 door.
1HGEG8558SL028894
197,464miles odometer/gauge cluster replaced with brand new o.e. unit at 165,928 by Zimbrick honda in Madison/sticker in drivers door jamb
Located near madison, WI.
B16A3 DOHC VTEC swap with 5 speed absolutely no rust on this car gauranteed. Interior is really nice with o.e. honda floor mats replaced recently
Brand new Tokico hp suspension 1.5" kit all around
Brand new Apexi Noir cat back exhaust
Hx 14" wheels in great condition with good tires
Recently had both rear 1/4 panels replaced with o.e. honda metal & painted entire car
4-2-1 header 6/23/'08, short ram intake with new k&n filter 3/28/07
i have reciepts with part numbers for all maintenence done with o.e. parts including
1/3/'07
-cap & rotor
-timing belt water pump
-all gaskets & o-rings-cam seals-etc.
-p.s. & alt belts
-fuel filter & ngk plugs
11/13/'07
-condenser cover
-iac & coolant flush
6/23/'08
-header
-cooling fan switch
2/12/09
-radiator cap
5/24/'09
-apexi noir exhaust
-spool valve gaskets seals & o-rings
-oil change & cleaned k&n filter
8/19/'09
-tokico suspension package
-bridgestone re960 tires all around
-alignment
-rear lower suspension bushings
Now for the bad, the car was recently in a front end collision so hood, bumper cover & support, fender, & all lights. heres some pics.
call me if you are interested in the whole car or parts. i would like to sell it as is but willing to pull the motor/trans/ecu, suspension, exhaust, wheels, etc
Nate
608.442.6390
I also have many other honda parts I would like to get rid of such as exedy clutches new in the box, energy suspension bushinghs new in box, o.e. honda bushings, gaskets, etc. tons of used stuff like motor mounts o.e., hasport, place, etc, core axles, em1 disassembled transmission, used flywheels o.e., jun, etc, '88-'91 rti transmission, random ingtercoolers conquest, starion etc, turbo kits edelbrock, garrett, etc...
i am looking for a pr3 head with original cams & caps if you have a decent one lmk.
1HGEG8558SL028894
1/3/'07
-cap & rotor
-p.s. & alt belts
11/13/'07
-condenser cover
6/23/'08
-header
-cooling fan switch
2/12/09
-radiator cap
5/24/'09
-apexi noir exhaust
8/19/'09
-alignment
Nate
608.442.6390
slowman
Oct 12, 2007 10:10 AM
Vtec GSR95
Oct 31, 2003 12:51 PM
