HELLP . no power at all in car!!!
Old Jan 19, 2011 | 08:04 PM
ek9sb's Avatar
Default HELLP . no power at all in car!!!
okay so here's the deal!
i have my 91 acura integra stored in the garage. once in a while i start it up because it's cold and all.
i put in the battery. located in the trunk. battery is fully charged. i go in and start the car. turn the key and power is on. and i started it. cranked about 3 to 4 times and ALL OF A SUDDEN the whole car lost power. so i checked the battery and it was connected. got back into the car no nothing. no lights. doesn't even click when you turn the key, nothing.
i need some help with this, anyone could know of the problem.?
thanks!!
Old Jan 19, 2011 | 10:40 PM
N/A's Avatar
N/A
Purpose Built
Default Re: HELLP . no power at all in car!!!
Hahahahahahahahahahhahahaha
Check fuses
Old Jan 20, 2011 | 05:55 AM
fcm's Avatar
fcm
Old Fart
Check the grounds.
If you have a main fuse/breaker off the relocated batt., check it.94
Old Jan 20, 2011 | 08:32 PM
ek9sb's Avatar
Originally Posted by fcm
Check the grounds.
alright will do . someone told me it might be my main relay???
and yes. i have a fuse off the reolated battery in the trunk. checking it now!
Old Jan 20, 2011 | 08:42 PM
91_LS's Avatar
Do you have any kills on the car?
Old Jan 21, 2011 | 06:04 AM
fcm's Avatar
fcm
Old Fart
No matter what is wrong with a main relay, [PGM-FI Main Relay] it would not cut all power to the car. 94
Old Jan 21, 2011 | 06:05 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Clearly a battery fuse
Old Jan 21, 2011 | 06:41 AM
vrrodri's Avatar
or the battery is bad...
Old Jan 21, 2011 | 06:53 AM
Mattb16teg's Avatar
Community Builder
Or your wiring to the battery in the trunk is bad, or as mentioned a ground is bad.
Old Jan 21, 2011 | 10:37 AM
cream1316's Avatar
newbie question fuse or battery have fun
Old Jan 23, 2011 | 04:44 PM
ek9sb's Avatar
what do you mean kills on the car?
sorry i'm a newbie lol
Old Jan 23, 2011 | 04:52 PM
ElementzofR's Avatar
kill switches
Old Jan 24, 2011 | 05:48 AM
fcm's Avatar
fcm
Old Fart
It is unlikely to be a kill switch as OP has no power at all, "ALL OF A SUDDEN the whole car lost power" unless of coarse it is a batt. main switch, [fuse or breaker].
Because this happened during cranking. [high current draw] it is most likely a connection problem, ground or power. 94
BB6Driver
Honda Civic (2006 - 2015)
Dec 1, 2018 08:30 PM
GPC91
May 23, 2013 09:15 AM
strils
Jan 11, 2007 08:06 PM
wingback44
Nov 14, 2006 03:28 PM
c for sea
21
Aug 12, 2005 06:38 PM
