Crazy idle while turning the steering wheel while parked???
Old Jan 19, 2011 | 01:57 PM
spamking98's Avatar
Default Crazy idle while turning the steering wheel while parked???
Does anyone know what would cause this...I have a 2001 honda accord 4cylinder ex and when I turn the steering wheel while parked either to the left or the right, the car seems like its going to stall. I just changed the spark plugs and wires but doesnt help.
Old Jan 20, 2011 | 09:37 AM
holmesnmanny's Avatar
Default Re: Crazy idle while turning the steering wheel while parked???
i would check the deflection of the power steering belt and also clean out the filter on the iacv
Old Jan 20, 2011 | 10:03 AM
Accordin2me's Avatar
Im not sure if honda uses them as I never thought to look but try the power steering pressure sensor its either on the rack or high side hose. It'll look like an oil pressure switch.
Old Jan 20, 2011 | 11:20 AM
chikin pickle's Avatar
Yes, honda does have a power steering pressure switch. I don't know about the 2000's but on the 94s the switch is a two pin green connector to the left of the oil filter. Fairly easy to get at from the bottom of the car.
kevinhughes13
Dec 20, 2013 11:08 AM
vietdragontekx
Sep 19, 2012 10:06 PM
ftrms
Mar 31, 2010 07:18 PM
ODDeyeC
Dec 15, 2009 05:26 AM
elizzabizza
Honda Civic (2001 - 2005)
May 28, 2007 11:53 AM
