Engine swap info?
Hi, i have a UK 6th gen 1.8vtec accord 2001, what do i need to fit a H22 engine in?
can i use any H22 or does it need to be originally from the Accord?
do i need all he engine mounts, gearbox, wiring loom, ecu etc?
thanks
thanks
You can get the whole complete swap from a Prelude including the gearbox(transmission) & swap it in.
I'm not sure on the 98-01 Accord about their driverside timing belt side mount if you should re-use the stock driverside mount or get a one; I'll let someone else chime in on this one. The wiring part, you'll have to re-use your F22 harness and extend the connectors that don't reach.
Get a OBD2 H22 for simplicity; it will make the wiring alot easier.
SamuraiSam
Sep 15, 2008 05:15 PM
matix
Sep 25, 2003 06:18 AM
