Help with SiR cluster into 91 rex!!! have searched
Old Jan 18, 2011 | 07:12 PM
4LugR's Avatar
Default Help with SiR cluster into 91 rex!!! have searched
ok so here is the problem. i have a 91 rex with a OBD1 gsr swap. stock p72 ecu. i just wired up the entire cluster and everything works except the speedo. there is a yellow/red wire coming off the back of plug B1 on the siR cluster. it goes to the VSS on the cluster. it is wired already to pin b10 at the ecu. which is the VSS pin on the ecu. now to run the electric speed sensor, i have the power and ground hooked up correct as i am recieving voltage out of the signal wire. i have tapped the signal wire to the b10 wire going from the ecu to the cluster. this is the only info i have found to help me over the two days its taken me to install this cluster. what a pita.. so with this way and all of these other ways i have tried i still have no speedo. someone please help!!
Old Jan 22, 2011 | 07:02 PM
gnxpro24's Avatar
Default Re: Help with SiR cluster into 91 rex!!! have searched
is it a cable or electronic vss?
jdmef69
Mar 30, 2013 05:42 PM
street-crx
Mar 7, 2007 05:14 PM
USDMSiR
15
Aug 31, 2006 02:07 PM
EF8IGHT
Feb 14, 2006 09:11 AM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
