Few questions about my b16 issues.
Old Jan 18, 2011 | 06:20 PM
b18bye's Avatar
Default Few questions about my b16 issues.
Hey everyone. I picked up a 1991 dx hatch with the obd0 b16 running a pr3 ecu about a week ago. When I first got the car it would hesitate and misfire hard at WOT soon as vtec engaged. I changed the cap and rotor and added 93 octane, it got a little better. New NGK plugs, a little better again. I also soldered all the shady ecu wiring and got rid of the all CEL'S. No more CEL. Today I changed the igniter and the coil( New coil was bad, so thats getting sent back) old coil back in, tried a friends coil runs the same.
With the new ignitor it will run a lot smoother, but still is SLOOOW, at about 6500rpms it just doesnt want to pull anymore and kind stays at that rpm, not doing much but being loud.
Checked the tps, it WAS 4.7v closed and .35 open. So I switched the inverted pins at the connector, .35 closed and 4.7 open (closer, will adjust when I have time)
o2's: The car has one o2 running to both inputs (C8 and C16 I believe)
What is my next step? Check ignition timing and adjust TPS?
P.S. The fuel pump is LOUD in this thing, just humms along all day. I am wondering if previous owner (who is special, front springs on the back and vice versa) added a walboro and no way to adjust it.
Any input or ideas would be appreciated.
Thanks everyone.
Old Jan 18, 2011 | 06:27 PM
b18bye's Avatar
Default Re: Few questions about my b16 issues.
Also, it randomy idles at 2k until blip the gas and it will settle down.
Just trying to add as much info as possible.
Old Jan 18, 2011 | 07:31 PM
Projekt_Ef9's Avatar
My b18a1 did the same thing until i changed the spark plugs, wires, rain seafoam through it, and rewired the two wires coming from the cam position sensor on the distributor to the ecu and havent had a problem since.
Old Jan 20, 2011 | 06:31 AM
b18bye's Avatar
Which two wires did you have to rewire? Do you mean you just had to re-do the connections or they were wired incorrectly?
Old Jan 20, 2011 | 09:26 AM
Shut It Fool's Avatar
my b16a did the same thing, when its in vtec around 7k it would misfire and make a loud popping sound and the tach would jump all over the place. I was running open manifold at the time and when i put a new exhaust on the car it never did it again.... what are you running for exhaust?
Old Jan 20, 2011 | 09:24 PM
I dont remember what pins they were at the ecu but they were the two wires that are not there on a DPFI Distributor. They were getting a bad connection at the ecu.
gringo7718
30
Jan 6, 2010 11:51 AM
ShortbusEK
May 23, 2008 07:05 PM
D-meet07
Jan 12, 2007 03:03 AM
ekb16
May 7, 2005 03:23 PM
RenoRacing
Apr 7, 2003 06:16 PM
