D16a6 Tranny question
Ok so I'm about to do a swap with my d15b 4 speed tranny and I have a a d16a6 that jumped time that i am working on building and so I took the tranny off to put it on the engine stand and when I did the main shaft has a metal ring around it at the end and it was broke. Its NOT the throw out bearing. Ill post pics if no one knows what it is but right now im at college so I can't till the weekend.
yeah it looks like it holds the shaft tight it the engine like a bearing. I know the throw out bearing is the like 2 inch round bearing with closer to the tranny and is actually touches the tranny. The part I am talking about only touches the shaft and engine and is the size of the shaft and does not go over the splines.
It's the flywheel pilot bearing.
It sits in the center of the flywheel. It shouldn't pop out of the flywheel, it's pressed into it. When you remove your original transmission inspect the pilot bearing thats in the flywheel and make sure it spins freely.
So is it the input shaft bearing or the flywheel pilot bearing or are they the same thing I will post pics Friday as soon as I get home.... it was broke in half and only half was on the tranny shaft when I pulled the tranny. It sits tight against the input shaft on the very end.
Ok so yes it is in the middle of the flywheel and not inside the tranny. a new one will just go in no problem? And would there be any other damage from it breaking
Your transmission is an 89
and you need to replace the pilot bearing, throwout bearing, but if you are Getting a new clutch. the kit will come with everything you need if its from like from advance auto or whatever
Ya i bought my clutch kit from advance and it came with everything yu need.. just cause its from a crx si doesn't mean 90-91.. your trans is an 89 though. Nothing wrong with that
Previous poster was frowning that OP may have an 89 trans rather than the 90/91 he stated.
My point is that it doesn't matter if he's using an 89, 90, or 91 since all use the same parts.
Ok I had read somewhere on here about tranny's and the differences I know that the 1988 has like 20 splines and will not fit a 1989-91 engine. I also thought that the 1989 had a different spline count from the 1990-91. Or was it just that the clutch was different.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-look-identify-si-tranny-1551508/
haha here is the thread some idiot posted wrong info but this has good info on it...
