to much power!!lol
Old Jan 18, 2011 | 05:22 PM
jdmda_1.7a's Avatar
Default to much power!!lol
sup HT.had a question for ya ef lovers.well ill start by saying that i have a b20z in my ef hatch,and the swap was done right by a very well known shop in my area!.but this is my first bseries swap in a ef ,and i was wondering if it was normal if the car had a quick *** throttle response!lol.(i know that sounds weird)but the reasons am asking is bc i can barely get of the gas and the motor will like jerk down ,kinda like when you drop it a gear.and when you barely touch on the gas it jerks you back haha.am not a noob.i had fast cars ,but never a ef.just wanted to see if ya had any ideas of what it can be.like is it normal for it to do that.
thanks in advanced HT.please no smart *** remarks.
Old Jan 18, 2011 | 05:34 PM
TunerN00b's Avatar
Default Re: to much power!!lol
Sounds like poor partial throttle tuning to me...
Old Jan 18, 2011 | 05:36 PM
alex14's Avatar
Does it have a lightweight flywheel? I just put one in mine and it does that now to.
Old Jan 18, 2011 | 05:38 PM
brettj20's Avatar
adjust your throttle cable, its probably loose
Old Jan 18, 2011 | 05:41 PM
jdmda_1.7a's Avatar
its not that already checked it.
Old Jan 18, 2011 | 05:43 PM
jdmda_1.7a's Avatar
and i forgot to say that my gas peddle is kinda hard to pouch down.think i might just have to loosen the cable??and to alex14 the fly will is not lighting.
Old Jan 18, 2011 | 10:55 PM
Radim's Avatar
TPS problem maybe?
Old Jan 19, 2011 | 12:58 AM
rd91sib18c5r's Avatar
What kind of mounts did you use? your probably
just not use to solid mounts.
Old Jan 19, 2011 | 03:42 AM
richboi's Avatar
"the fly will is not lighting" What?.....anyways.....Dude, you can never have too much power, haha. But seriously,....maybe your suspension is just bad....try replacing those, one way or another, youre going to want aftermarket suspension. And I dont mean cheap ebay coilovers....because if you have those, then that answers your question. good luck bro.
Old Jan 19, 2011 | 02:22 PM
brettj20's Avatar
You said your throttle is hard to push? That could point to a bad throttle cable, or try moving your throttle butterfly by hand, if its really hard to move then that could be your problem, could be gummed up.
Old Jan 19, 2011 | 03:43 PM
Nooch's Avatar
this
Old Jan 19, 2011 | 03:52 PM
mruneek's Avatar
your problem is when you let off the trottle the motor jerks down? right?
1) back pressure (what size exhaust are you running, if any?)
2) not used to soild mounts
3) fuel mapping wrong or off (what kinda ecu?)
Old Jan 19, 2011 | 04:03 PM
99blackcivicSi's Avatar
theres a lot of odd responses in this thread, from the hundreds of swaps i have done and the dozens of swapped honda's i have had on a stock ecu or whatever other EMS i used, if you downshift and your at about 3.5-4k and you blip the throttle yes its going to be a little jerky this is par for course if your using aftermarket mounts
now if you find it to be excessive check play in the throttle cable or there for lack of if your barely touching the throttle pedal well then its too tight if you have excess play in the pedal then its too lose, also the throttle plate COULD be sticking in the bore and be misadjusted.
if those are all good then check your TPS voltage make sure its sweeping correctly after you check those please return and tell us your findings those are all good starting points and take only a few minutes each to check.
Old Jan 19, 2011 | 05:47 PM
jdmda_1.7a's Avatar
i know you can never have (to much power)lol.but what i ment by that is the power to weight ratio.and my suspension is all skunk2 .
Old Jan 19, 2011 | 05:54 PM
jdmda_1.7a's Avatar
thanks for your help man that really helped out !.am gonna check in the morning asap!.and for people asking what mounts i have.they are Innovative Mounts.the strongest ones they have.am thinking my plate could be sticking.or its to tight .i will fined out in morning lol.thanks a lot again for help
Old Jan 20, 2011 | 01:03 AM
Fo-Do Fanatic's Avatar
Man, you REALLY need to use correct punctuation and grammar. It's hard to read your posts
Check your throttle cable and your throttle body plate.
Old Jan 20, 2011 | 01:17 AM
cali-boi_eg6's Avatar
damn i thought this thread was gonna be about a 900hp civic or something
Old Jan 20, 2011 | 09:54 AM
jdmda_1.7a's Avatar
i have 215to the wheels that's all i need right now
Old Jan 20, 2011 | 09:57 AM
jdmda_1.7a's Avatar
not trying to sound like a douche or anything.but am on the computer not at school so i just want to let loose and not worry about my grammar and punctuation.thanks for input.
Old Jan 20, 2011 | 07:32 PM
jdmda_1.7a's Avatar
thanks guys for all the help!.it was the plate that was sticking
Old Jan 20, 2011 | 08:50 PM
brettj20's Avatar
sweet, i had the similar problem.
Old Jan 20, 2011 | 09:27 PM
jdmda_1.7a's Avatar
what was yours doing?
Old Jan 21, 2011 | 03:24 AM
LudeEFv2.4's Avatar
My old title sucked.
Originally Posted by Nooch
this
x2
Old Jan 21, 2011 | 05:20 AM
Creator's Avatar
I've had this problem too....many of the after market throttle bodies have this issue. Try getting some BG throttle body spray, and follow the instructions.
so yes x 3
Old Jan 21, 2011 | 07:26 AM
lunalink's Avatar
TOO much power!!lol
change title
