PA 89 ef si ls/vtec fs/ft??
ft/fs built ls/vtec 89 si ef?
hey whats up i have a ls/vtec ef
built bottom end stock 1st gen b16 head
gsr cams
bottom has 6k built it last december
270 compression all 4 cylinders! (done in 06/2010)
81.5 ml forged srp pistons and forged eagle rods
acl bearings
arp head studs
thin 2 layer head gasket
new piston rings
stage 2 clutch
new oil/water pump
tri-y 2.5 in headers full apexi exhaust with ws2 apexi muffler
kyb struts all around coilovers
front and rear cambers battery in trunk
b16 cable trans
obd1 gsr dizzy
phearable reburnable ecu
vtec hits @ 5200
redline@ 9000
check engine shift light @ 8600
hasport motor mounts
14 in. steelies with 95% tred
blox lower control arms (red)
13" steering wheel with red h horn
sunroof
rear disc conversion
new nrg trail arm bushings
94 integra front knuckles
hasport shift linkage
s2 short shifter
gsr shift ****
fuel pressure regulator
crx front lip
si interior
all 4 mud flaps (that say honda)
inspected til december 2011
pulls very hard
nice set up
theres alot just cant remember right now
shootin for 3500$
let me know..
red si 89 call me @267-475-1874
gsr cams
acl bearings
arp head studs
new piston rings
stage 2 clutch
new oil/water pump
b16 cable trans
obd1 gsr dizzy
vtec hits @ 5200
redline@ 9000
sunroof
s2 short shifter
gsr shift ****
crx front lip
si interior
pulls very hard
nice set up
shootin for 3500$
let me know..
818SpoonITR
Apr 12, 2008 11:33 AM
