Massive Universal part out + sct tuner, mafia, silicone hoses, turbos. Lots of PICS!!
Massive part out please text me at 281-814-3206 Sean
Oil Breather
$70 shipped
vibrant 2 1/4 V-Band clamp with 2 flanges (steel I think)
$48 shipped
Vibrant Turbo Flex Coupling with Interlock Liner 2 1/2
2 1/2 diameter 6” long
$35 shipped each
vibrant performance 4 Ply 2 1/4 to 2” reducers
$30 shipped for both
4ply custom made silicon hose done at vibrant 2”
Has a 6” kick flared out to 2 1/4 but can be cut to 2” The other side is a 45 but its it kicks out to the side about 2”. 10” of straight 2”
Has a 45 and a 2” kick and about 14” of straight. Small side 2” inlet, large side (kick side) 2 ¼. This is a lot of hose… $60 shipped
vibrant performance 4 Ply Reinforced Silicone Elbow Connector - 2" I.D. - 90 deg. Elbow (BLACK)
Ive got 4 of these $30 shipped each or all of them for $95shipped
K20 porshe turbo, this is a great turbo for and 4cly, or for a 6 $280 each or $500 for both
ive got 2 of these i was going to use on a pair of dune buggys i was building, i got them cause they work on ANY ecu (like ame fic just not quite as goood)
Details and features SMART TUNER SMT(5)
The SMT5 is a piggy-back controller which modifies the signals to the standard ECU to achieve better economy and more power. It can be used to "iron out" the manufacturing tolerances of a standard engine, and to achieve a truly customised engine performance. This system is a pre-requisite to cam changes, exhaust and manifold changes, and to any engine modification. To do as many different engines as possible, the SMT5 is packed with the following features:
Feature Benefit
Throttle Sensor learning feature Fits to any throttle position
RPM Calibration To suite your installation
High RPM range Racing?
Fuel map with 128 sites Smooth Programming
Ignition Map with 128 sites Fine Ignition resolution
Injection Map with 128 sites For extra (boost!) injection
0 - 10 volt analogue range Allows tuning of all models
6 Amp injector drive Handles 6 x 16 ohm injectors
Various ignition outputs For the most stringent applications
Selectable Trigger points To suit
Programmable Cylinders It works on any amount of cylinders!
Selectable polarity To Suite
Can handle interlaced signal For 4 cylinders ignition output tuning
Balanced Inputs Inverted Outputs
Missing Tooth Signal For up to 2 teeth advance/retard
Ignition output limit Limits max. advance and retard
Fuel High low limit Prevents overdriving the ECU
Small Size Fits Anywhere
Low Battery Drain Simple Installation
Self Checking Test Available For Extra Confidence
Map Switchable While you drive
All Inputs Protected No mishaps!
Crystal Controlled For Stability
Encapsulated For Moisture and Dust
Easy Tuning Software DOS or WINDOWS
Low Component Count High MTBF
10 MIPS computing To facilitate quick engine response
Signal Conditioning To prevent miss trigger
Engine profiles (library) Easy set up
Software & Manuals
http://www.perfectpower.com/downloads/login.asp (got make a user name and password)
$140 shipped
SVT Ford fuel pump, with cage. Should work with our car and minor modification supports about 450hp. $135 shipped
Fuel Regulator Old school
$80 shipped
SCT SF3 /X3 Power Flash
Used this 1 time then used it to put it back to stock
$250 shipped
86-04 Diablo Sport Mafia Mass Air Flow Calibrator - F7373
New - $140 shipped
B series intake manifold stock with injectors and fuel rail
$75 shipped
7.4lb Clutch Masters Alu flywheel - B serise
$120 shipped
Oil Breather
$70 shipped
$48 shipped
$35 shipped each
Feature Benefit
Software & Manuals
$140 shipped
$80 shipped
$250 shipped
New - $140 shipped
$75 shipped
$120 shipped
Make some offers im open to trades I need the following and can kick in cash if needed
Crx coilovers with adjustable danpining
Skunk2 upper or rear camber kit
4lug rear skinnys
New 13" slicks
Aem ems
B series harness (rywire quality)
Crx suspension bushings
4lug rear skinnys
New 13" slicks
Aem ems
ub3rn00ber
Jan 20, 2011 09:21 AM
